BIKELAND > FORUMS > ZX-14.com > Thread: Pulled flies out, GiPRO ATRE won't pwr up? NEW TOPIC NEW POLL POST REPLY
dbzx1409
posted October 16, 2013 01:52 PM
Okay today I decided to pull my flies out on my 09 zx-14. I have a GiPRO ATRE installed and I decided to leave it installed but to put it in transparent mode (disable), but when I turned the key to on, I didn't get any indication on the indicator, I can only assume it's not getting pwr but not sure how pulling the flies we cause this??
zixxer14
Damn that was Quick
posted October 16, 2013 04:35 PM
Pull the tre & check for connectors you missed when you put it back together.
dbzx1409
posted October 16, 2013 05:04 PM
Zixxer14 after I made this post I decided to start the bike and the TRE powered up? Well the problem is I can't make changes when the bike is running so it's not helping me. Only wires that got disconnected were to the fuel tank.
Seno
BANNED FOR LIFE!
posted October 17, 2013 03:46 AM
Double check your connections. I had the ATRE on my 07 and had some minor glitches also. It looks great but it is a little finicky, not to mention there are a ton of options that have to be programmed or set up.
dbzx1409
posted October 19, 2013 06:38 PM
Okay I got! I had the pwr wire connected to my LO-Beams that's why I had no pwr in the on position.
BIKELAND > FORUMS > ZX-14.com > Thread: Pulled flies out, GiPRO ATRE won\'t pwr up? NEW TOPIC NEW POLL POST REPLY
0.23412585258484 seconds processing time
