BIKELAND > FORUMS > ZX-14.com > Thread: 06 zx-14 code 31..help!!!!!! NEW TOPIC NEW POLL POST REPLY
779civic
posted September 07, 2013 03:14 PM        Edited By: 779civic on 8 Sep 2013 01:03
I was getting FI code 31(down sensor). I replace the sensor and it quit for about a month. Now its back on. I traced the wires to the ecu and cant find any breaks. Is there anything else i should check? Could the sensor be bad already? It usually happens when im at a stop. Until today and it died while driving down the road. The bike has never been laid over, and is basically stock.
Lou_ZX12R
One Day at a Time
posted September 07, 2013 06:23 PM
Electrical is not my specialty. But here goes. Could there be something else causing the code instead of the sensor? Can you take the sensor out and test it to make sure it is faulty? If its not faulty what circuit or sensor is before it. It could be causing the code.
2000 ZX12R 40shot
2012 ZX14R
2009 Concours 14
779civic
posted September 07, 2013 07:15 PM
I was thinking it was something else, but wasnt sure what it could be. How do you test the sensor? I looked at the wire diagram and there looks like some other sensors were connected to it. Im not real good with wire diagrams. It looks like these sensors connect to it but i could be reading it wrong. 2-Main Throttle Sensor ,3-Subthrottle Sensor, 6-Joint Connector I, 7-Joint Connector J,8- Water Temperature Sensor. Not sure if any of these would cause a problem with this.
trganey
posted September 08, 2013 02:48 AM
I would start by bypassing the sensor. That would cut your work in half.
Your next question is likely to be: How do you by pass the sensor.
I can't remember what the exact process is but I'm sure if you did a search on here or a couple other forums you could find it pretty easy.
779civic
posted September 08, 2013 07:45 AM
Well ill try to bypass it and see if that works.
trganey
posted September 08, 2013 10:30 AM
I didn't mean to sound like a dick, but if you bypass the sensor and it fixes the problem then you know it's in the sensor. If you bypass it and it still don't run then it's in the harness or ECU. jes my .o2
779civic
posted September 08, 2013 11:07 AM
hey anything helps. thats why im on here. Is there anything else that could be going out that would cause this? The sensor is new. Got it from Kawasaki dealer here in tulsa about a month ago. Do you think the ecu could be going bad?
posted September 08, 2013 11:10 AM
I would check the make sure that your fairing stay is tight, along with the sensor. Excessive vibration could cause this.
Just a thought.
779civic
posted September 08, 2013 02:26 PM
the bolts are tight. but the rubber inserts seem a little worn. kinda seems like it should be tighter. idk
0.22642493247986 seconds processing time
