BIKELAND > FORUMS > ZX-14.com > Thread: Clutch fluid change effect NEW TOPIC NEW POLL POST REPLY
Zoom
posted July 11, 2013 05:09 PM
Hey guys, I ride a 09 zx14, I had a rear brake m/c reservior leak and changed it out, bled rear brake. I decided to change out cluth fluid being it was cola colored and now its ginger ale colored with fresh fluid. I bled it, started up, pulled in clutch, put in gear and it goes forward with clutch in. I bled it again and it stays stable with clutch in, I did notice that now it wants to lunge forward even more stronger than before, like more bite. Is that what a fresh fluid change to the clutch does?
MotoCycho
posted July 12, 2013 09:19 AM
No. That is what warped steel clutch plates cause. Still.. bleed it some more and make sure you have no air. Try a different adjustment at the lever.
Zoom
posted July 12, 2013 11:21 AM
Warped? I hope that's not the case with me. She only has 12,500 miles, never saw the track, only ride hard on the streets. I bled her again now there's more pressure n less play. Pressure feels like it did before the fluid change.
0.21302008628845 seconds processing time
