BIKELAND > FORUMS > ZX-14.com > Thread: 07 ZX14 Accessories onto 2012 NEW TOPIC NEW POLL POST REPLY
sweetfa65
posted July 07, 2013 04:10 PM
Hi all. I'm considering trading my 2007 for a 2012 ZX14R and I'm wondering if the following accessories I have on my 2007 will fit straight onto a 2012.
Vortex Stealth rear sprocket (standard tooth), tinted turn signal lenses, Zero Gravity screen, radiator guard, Pazzo levers, Throttlemeister bar ends, fender eliminator, frame bolt caps, Genmar bar risers, PAIR (smog) system block off plates.
My bike is in bits at the moment doing a valve shim service, so pretty much all of these bits are easy to get at to swap for the stock parts when I put it back together.
I'm having a look at the 2012 later today, so any urgent help would be awesome. Thanks.
'2013' SE Spark Black & Golden Blazed Green ZX14R. Bog stock after trading my 07 ZX14.
SnuffyZX
posted July 07, 2013 05:42 PM
Hey Sweet
Not Sure About the Sprocket or the block off plates but the rest should all swap right over, I went from an 07 to 12 and just about everything I had swapped with no problem.
Snuffy
2012 S.E. Golden Blazed Green 14R
Brocks CT Dual Exhaust
Brocks Ohlins Damper
Ohlins Rear Shock
MRA Touring Screen
DDM HID's
COX Radiator Guard
Power Bronze Tire Hugger
Clear Alternatives Intergrated Tailight
2007 Candy Plasma Blue (Retired)
quick6
posted July 07, 2013 07:23 PM
valve covers are the same. block offs should work
2006 zx14, fully dressed and sliding(Charlie Sheen)
0.2926721572876 seconds processing time
