BIKELAND > FORUMS > ZX-14.com > Thread: 2008 Questions NEW TOPIC NEW POLL POST REPLY
sceptre
posted June 06, 2013 08:06 PM
2008 Questions
Hey guys, I have a couple of questions about my 08SE. First, I can't seem to get the idle adjustment right. If I adjust it after the engine is heat soaked then it idles so low on startup that I'm not sure it even build oil pressure. If I adjust it with the engine partially warm then its much too high once completely warmed.
Second, are the gauge voltage readings usually wrong? My battery measures 12.6 but dash shows 12.2v. Is there a way to adjust?
Thanks a million for any info!!
2008 ZX-14 SE
0.24424600601196 seconds processing time
