BIKELAND > FORUMS > ZX-14.com > Thread: 2008 ZX14 cams NEW TOPIC NEW POLL POST REPLY
lazarosp
posted May 12, 2013 04:09 PM
2008 ZX14 cams
I have a stock motor ZX14 with pc-v, full tiforce and an air filter.
I want to make some more power (previus I had another ZX14 2007 that made 215hp with je pistons, muzzy cams, ported head etc). Is there any good choice of cas to make power on a stock motor?
If I mill the head with stock cams will it make any more power or it will lose high end power and gain low and mids?
08smokes
God is love.
posted May 12, 2013 08:37 PM
I've done this to mine. In 2012 I did a .020 mill with mild porting and 47mm TB's- picked up 20 hp and gained 2 tenths in the 1/4 mile and picked up roughly 4 mph.
For 2013 I tore it apart and installed Kibble White Black Diamond valves w titanium retainers and their HD valve springs. I purchased a set of Web Billet Cams (mildest available) and picked up an addditional 7 hp on the Dyno.
If I were you, i'd stick with the mill- best bang for the buck. Those Cams ran me $1300.00. Not worth it for 7 hp.
Mike
smokinstorm
Old Drag Racer
posted May 13, 2013 12:17 AM
Mike
If you'd flycut and/or put in drop-in pistons to allow for a much higher lift cam with more duration do you think you'd have picked up a lot more horsepower from the cams? I'm thinking yes but just curious as to your thoughts as well.
2009 Monster Edition ZX14
It's all stock I swear. Well...almost.
2005 Turbo Busa
2001 GSXR 1000
Looking for a 1985 GS1150E
0.25218391418457 seconds processing time
