BIKELAND > FORUMS > ZX-14.com > Thread: Rotella Oil NEW TOPIC NEW POLL POST REPLY
astyle96
posted May 07, 2013 03:35 PM
Rotella Oil
Someone give me some input on Rotella Oil....... Rebuilding my 2006 ZX14 that spun a Bearing !!!!!
What is the best Oil for the Beast !
astyle96
  Ignore this member    Click here to visit astyle96's homepage.
carabuser
posted May 07, 2013 04:32 PM
Rotella T6 is good afordable stuff, amsoil and motul also make great products at a premium price ... I'm no expert, and am fairly new to the 14R, but used. rotella for many years on the busa, with no problems ...
Lou_ZX12R
One Day at a Time
posted May 07, 2013 05:28 PM
Did the oil you were using cause the spun bearing? If so what was it, I'm sure the rest of us don't want to use it.
If not what's the reason for switching, maybe a bit more security?
Rotella, amsoil, mobil 1, that purple stuff take your pick all great oils. My favorites are castral edge or Valvoline both full synthetics and 10/40.
2000 ZX12R 40shot
2012 ZX14R
2009 Concours 14
BobC
posted May 08, 2013 04:29 AM        Edited By: BobC on 8 May 2013 13:56
My 2012 bike is up to around 1000 miles, it's done one LSR meeting and is now due another oil change. It had the original lubricant from Kawasaki up to the first service at 600 miles, before the bike was raced, when it was filled with Rock Oil semi-synthetic by the dealer.
I've ordered a can of Castrol Power 1 Racing, 5W 40. It's a fully synthetic and available by special order only. It's about £75 ($115) per 5 Litre can and Castrol make some impressive claims for its performance. I can't get the Alisyn over here in the UK, the oil which Brock recommends, so I thought I'd try the oil that's used by the Honda Britain race team. I was at a seminar given by one of their top development engineers the other month and according to him they have no engine blow-ups or problems with their race engines attributable to this lubricant.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
riaansh
posted May 08, 2013 12:10 PM
Another spun bearing. Is the older bikes showing some weakness now? Man what happened to your bike resulting in the spun bearing?
Bob I also used Castrol Power 1 racing and could feel the difference in acceleration as they claim. Changed now to Liquid Molly and am also impressed at this stage. Need to get more miles on it to make a proper evaluation of the oil.
I don't think oil will make a big difference when there is a problem somewhere as long as you use a decent recommended oil.
BobC
posted May 09, 2013 11:29 AM        Edited By: BobC on 9 May 2013 19:30
My Castrol Power 1 Racing 5W-40 came in today, was given a good discount, only £55 for 5 litres. I've got the Brocks clutch mod to install too, thanks Brock, so I'll be spending a couple of hours in the garage in the next day or two.
Stock wheelbase
posted May 09, 2013 05:08 PM
73,000 miles on my '10 Concours14 with Rotella JASO motorcycle rated oil.
At 200,000 miles I'm parting the bike out on ebay....thanks Shell/Rotella!
astyle96
posted May 09, 2013 07:00 PM
I was useing Amsoil and that was not my problem.
I was told that zx14 has a problem with how the the oil pump is connected to the engine, it seams that the the pump does not have a gasket between itself and the engine , during normal rideing conditions the engine heats and cools which allows oil to be returned to the oil pan without being detected, as a result vital engine parts are being starved for oil, My engine light never came on, I started to hear a slight tick in the motor wich sounded like a loose header bolt or crimped header gasket, after a week or so it got louder . After the engine was taken apart it revealed a spun bearing Their is a after market mod to prevent this I am told so that was the first thing I told my engine guy I wanted...
If anyone has Info please share it with me!!!!
Not sure on what year models have this problem but I have an 06 zx14!!!!!
astyle96
frEEk
posted May 10, 2013 08:47 PM
Snail from LAB will also give a recommendation for Rotella. He uses it on his LSR bike. I've used it for the last few oil changes without complaint too, and can't beat the price.
SteveWFL, 200k mikes on a 2010. that's insane.
Ozonkiller
posted May 11, 2013 08:08 PM
There is no bad oil. Some are just more exceptional than others.
Let me guess. #3 rod?
Tom
moko
posted May 13, 2013 02:40 PM
more important to me than the brand....is i run the oil a 1/2 qaurt more than level.
i have used rotella for years and like it
if money was no object...ide run motul 300v.....but again,i run my oil to the top of my window....and i did my best to copy Doug's oil pipe to return pickup,on my zx11......just for added safety in wheelies,quick launches,and high rpm runnin
so what every bike i have....
1-check oil alot,and keep on the high side
2-if running a built motor and/or a wheelie freak.....oil pan mods
krexken
posted May 17, 2013 02:49 AM
I rebuilt a 14 a while back that had spun a rod bearing because his motor didn't pick up the oil after an oil change. His oil light stayed on too long. I've seen this happen several times. If your oil light doesn't go out immediately after an oil change, loosen the filter and few rounds, crank the bike for a second and oil should gush out around the filter. Tighten it back up and you should be good to go. Everything I build gets Rotella. Seems most rod bearings I see die from lack of oil.
gilberjj
Friend of Fast
posted May 17, 2013 11:37 AM
Rotella is great stuff. There's a couple pro-street owners on psychobike that run rotella. Honestly, if it's good enough for them, its good enough for me. 600+ hp on those bikes btw....
CajunBoyz
posted May 17, 2013 02:09 PM
Bobby914
Dragon slayer
posted May 20, 2013 09:14 PM
What weight rotella are they running, and its T6 right?
RobBfasternu
CajunBoyz
posted May 21, 2013 06:50 AM
Thats what i use, T6 5w-40w..
slacker83
posted May 21, 2013 07:25 AM
Been using rotella in 2 suzukis, 1 kawi, and one aprilia with no problems. Also was running it in my gto and truck.
0.23606705665588 seconds processing time
