BIKELAND > FORUMS > ZX-14.com > Thread: muzzy 3" lowering blocks install NEW TOPIC NEW POLL POST REPLY
dp0289
posted April 17, 2013 05:55 PM
I bought the muzzy fork lowering kit for my 07 zx14. I want to know if there is any special tool I NEED for the install and if someone has pictures or a walk through of how they did it. The directions are brief and only mention where to put the small spacer in the kit. can anyone help with this install?? im not riding on the street and im not going to a dealer.
posted April 18, 2013 05:10 AM
You must be talking about for the front forks..
If you have never done it you better take it to someone that has. I believe you do need a special tool but you must be exact in putting the correct amount of fluid in each fork.
Do you do a lot of drag racing? Have you read up pros/cons to lowering the forks internally?
dp0289
posted April 18, 2013 06:52 AM
Yes the front forks. Like i said im not taking it anywhere. I do all the work to my bike. All i do is drag race. my 10 had internally lowered and cut forks and i still rode it on the street no problems and i had leaky seals. im only asking if anyone has pictures or has done this that can explain it alittle better than the directions that came with it.
dp0289
posted April 18, 2013 09:21 AM
well i just broke down and spent $250 on all the proper tools needed for install. when i get everything in ill let you know how it went
toledoUPSguy
An old guy with a new toy
posted April 18, 2013 06:43 PM
I'd like to hear the pros and cons of internal fork lowering please. I just dropped my trees 30mm down the tubes.
The man on top of the mountain didn't fall there.
2014 ZX14r in nuclear sunset orange and black
dp0289
posted April 18, 2013 06:53 PM
im only racing so im not worried about the handling loss of it if there even will be any. im doing it for the biggest pro in my eyes. NO WHEELIE! lol. thats is my biggest reason for doing it.
bigwil
06 zx 14 turbo stage 3
posted April 19, 2013 09:43 AM
Those muzzy blocks sucked any blocks suck never had a set that worked right for the 250 you spent on the tools terry mcintoch would do them right for 250 ind fast tun around
bigwil// going fast aint easy so turbo it
dp0289
posted April 19, 2013 11:53 AM
I think ill get good use of the tools. But can you explain why they suck?
Newf14
2007 ZX1400
posted April 20, 2013 03:57 PM
I have them in my ZX14 they installed really easy, I already had the tools to do the job I do a few sets of shock seals for people.....
Newf14
dp0289
posted April 20, 2013 04:19 PM
Can you explain to.me what the deal is with the small and large sleeves? The dorections only mentioned using the snall
Newf14
2007 ZX1400
posted April 20, 2013 07:46 PM
The large ones go on the top of the spring where the plastic ones were, the small ones go on the bottom after you take the cartridge apart. I used two small pipe wrenches to do that.If you want more info let me know.
Newf14
dp0289
posted April 22, 2013 07:08 PM
WHY??? why do they suck?? what do you recommend?
Newf14
2007 ZX1400
posted April 24, 2013 10:03 AM
What aint there to work u install the blocks they dont move they do what the plastic spacer dose my shocks work perfect with muzzy blocks.
Newf14
BIKELAND > FORUMS > ZX-14.com > Thread: muzzy 3\" lowering blocks install NEW TOPIC NEW POLL POST REPLY
0.29269599914551 seconds processing time
