coliver
posted April 07, 2013 09:27 AM
06 zx14 running bad
hey have anybody had any problems with they zx14 spitting too much fuel and sputter when you twist on it?????? I am ive took the pc5 off I thought that was the problem but it still does it with the pc5 off I don't know what it is doing or why but can anyone hepy please!!!!!!!!!!!!!!!!!!!!
the beginner
joel787
posted April 08, 2013 10:57 AM
More info
Lou_ZX12R
One Day at a Time
posted April 08, 2013 01:36 PM
quote: More info
As stated,
did you make any recent changes?
Did this happen immediately or slowly over time?
Was your last gas purchase from a strange station?
Explain what.when it occurs
With the above someone should be able to at least point you in the right direction.
2000 ZX12R 40shot
2012 ZX14R
2009 Concours 14
coliver
posted April 08, 2013 02:11 PM
I took it to the track and it ran 9.55 and then it set for a week. I was going to ride but that started.
but I rode it this weekend and it still suck but I was thinking that its either too much fuel or not enough .....
the beginner
coliver
posted April 08, 2013 02:25 PM
could it be the fuel pump?????????
the beginner
joel787
posted April 08, 2013 08:59 PM
If the fuel pump is bad i dont think the bike would start at all..ii would start checking injector locked open or bad plugs
coliver
posted April 09, 2013 07:48 AM
ok ive checked the fuel pump its good and after it started that the first thing I had done was new plugs...
the beginner
krexken
posted April 09, 2013 07:24 PM
I have a friend with one that's doing almost exactly what yours is doing. New plugs did nothing. He also unplugged the PC and his is still dumping fuel. No codes. Would a stuck injector throw a code? That's kinda what it sounds like may be happening.
You don't ride a blue 14 by any chance? LOL
joel787
posted April 09, 2013 09:16 PM
Havnt had this problem yet, but ive seen a closed injector blow a seal and loose stacks make u lean...try checking those...for around $60 you can get the injectors flowed and rebuilt
coliver
posted April 16, 2013 10:19 AM
I put a new ignition coil on the bike just a waste of money this zx14 is starting to make me sick.......
the beginner
big nickel 14
posted April 16, 2013 11:42 AM
my 07 did the samething,when i turned the key to on she would set up but never come out of warm up, just kept dumping fuel in. turns out needed cleaning, tb assbly
coliver
posted April 19, 2013 06:05 AM
what does the tb assbly mean??????
the beginner
Beondwacko
posted April 19, 2013 07:34 AM
throttle body
big nickel 14
posted April 20, 2013 07:23 AM
bad mapping was root cause i believe. mines been good ever since. struggled all last summer with this. no codes, if i rode it it would clear up after 10 or so kms. next start up after sitting same thing
coliver
posted April 22, 2013 09:02 AM
ive had a brocks map in the bike for a while and the bike ran great but still haven't got the problem solved
the beginner
big nickel 14
posted April 22, 2013 04:39 PM
ohm test sensors, stick coils clean throttle bodies, checked fuel, like lou12 said, did you remove secondarys?
kostasva
posted April 23, 2013 10:44 PM
my friend , check the map sensor of the throtle bodies , if it is connected to the vacum hose
coliver
posted April 24, 2013 01:50 PM
I will try that
the beginner
rquinn
posted April 24, 2013 06:01 PM
Did you leave MR9 or MRX01 in the tank
RON QUINN
coliver
posted April 25, 2013 04:36 PM
what is that I have no idea
the beginner
coliver
posted April 25, 2013 04:37 PM
in getting ready to just throw me bike in the trash
the beginner
big nickel 14
posted April 25, 2013 10:10 PM
rquinn is talking race fuel, if you have a buddy with a 14, swap out the throttle bodies, gotta start process of elimination
1badzx12r
posted April 26, 2013 04:52 AM
quote: my friend , check the map sensor of the throtle bodies , if it is connected to the vacum hose
"this" being you had your paws in there changing coils and spark plugs ..good chance you unplug this sensor .. or knock a vacum hose loose
