BIKELAND > FORUMS > ZX-14.com > Thread: PROGRESS AT THE DRAG STRIP WITH THE 14R....9.2 @159 mph STOCK WHEEL BASE NEW TOPIC NEW POLL POST REPLY
zx12mark
posted April 06, 2013 11:25 AM        Edited By: zx12mark on 6 Apr 2013 20:46
temps Low 50`s and track was never prepped period as told to me by track official. I made 9 pass`s The last pass being the quickest at 1:30 am.350 runs by mostly junk street cars and pick ups.You could see oil and other wet drops and trails on the track. A lot on spinning at the start and bangin into gears. I did the best I could.I need a teacher on my clutch hand.
posted April 08, 2013 01:51 PM
Nice !!!
coliver
posted April 08, 2013 02:19 PM
hey what all have you done to your bike to get it to run like that I am 9 over and a brocks pipe and a pc5 16/46 gearing but its a 06
the beginner
zx12mark
posted April 08, 2013 08:26 PM
I weigh 140#.I ride the bike on the street as much as possible so I don`t want a full time drag bike at this point.........STOCK WHEEL BASE
When I go to the track I ride it there.About 20 miles.
Set up is like this.
Lowered to middle hole and forks slide up 3/4 inch.Also strapped at the track .Brocks ct meg full system. pc5 with pump track 89 Shell gas map. Guhl drag flash 2.Mirrors off.2 tooth smaller rear sprocket.( THAT`S RIGHT 2 TEETH SMALLER REAR SPROCKET 40 tooth) on a spare zx12 rear wheel with a 190 u-soft tire.20 psi.Dale Walker ps3 push button electric shifter. Brocks slipper clutch mod eliminator.
The next time I go I plan to run the mr12 race gas and map.Suppose to add 10 more h/p.Around 220 rwp total.
coliver
posted April 25, 2013 04:45 PM
that guhl drag flash and the brocks slipper clutch that is all that make the difference to the zx14 I need all the help I can get
the beginner
Master
If it ain't fast it aint me
posted April 30, 2013 06:39 AM
nothing going to help you more than weighing 140#,s
biggmoinc
posted April 30, 2013 12:53 PM
Awesome! What gear do u go thru trap...top of 3rd?
biggmo@aol.com
zx12mark
posted April 30, 2013 09:55 PM
Yes.I have my dyna shift light set to flash at 11,125 rpm`s just as I push the button for forth gear.That`s with the 40 toofer on back.
0.23255491256714 seconds processing time
