BIKELAND > FORUMS > ZX-14.com > Thread: Intstalled a Hyperpro today-some pics NEW TOPIC NEW POLL POST REPLY
BenzTech
Dirty Jersey
posted April 05, 2013 11:09 AM
I was trying to decide between a Hyperpro and a GPR for a while. I chose the Hyperpro because of the active dampening feature-plus it looks cool. Its the newest generation with the updated mounting brackets which are black now (used to be gold). Install was very solid, no drilling. Mounting hardware is very high quality and looks to be stainless. Ill post back on how it feels.
07 ZX14 SE with chicken strips
toledoUPSguy
An old guy with a new toy
posted April 07, 2013 06:56 PM
where did you get it and how much? that is the combo i want to add to mine. whose brake fluid resivoirs are those?
The man on top of the mountain didn't fall there.
2014 ZX14r in nuclear sunset orange and black
BenzTech
Dirty Jersey
posted April 08, 2013 03:58 AM
Got it from Motomummy for $398, cheapest around. The reservoirs are Evotechs, also from Motomummy.
toledoUPSguy
posted April 09, 2013 12:41 PM
Did the reservoirs mount right up with no fiddling around? Again, looks great.
BenzTech
Dirty Jersey
posted April 09, 2013 01:15 PM
Thanks. There was some fiddling to mount the reservoirs. The brake side only required putting a 90deg bend on the supplied Evotech bracket...easy. The clutch side was different. I ended up taking off the stock res. bracket and cutting the top off, then giving it a satin black finish. Then I took the supplied universal bracket supplied and basically made a really small flat spacer. All the spacer is doing is raising up the clutch res. approx 1/2 inch so the feed hose can be run from the underside. The stock res. had a side exit. All in all, your looking at about an hour of fiddle time...not too bad for the results you get.
0.2845139503479 seconds processing time
