BIKELAND > FORUMS > ZX-14.com > Thread: Popping during deceleration(wtf is it?) NEW TOPIC NEW POLL POST REPLY
iTameBikes
Bad bikes tame stud dikes!
posted March 13, 2013 06:38 PM
FYI I just purchased this bike and have no clue if its bone stock or not. Has Muzzy 4-2-2.
Meangreen14
posted March 13, 2013 06:48 PM
If secondary's are removed it will pop & spit flamed like crazy with aftermarket exhaust, get you an Ivan's DECEL TRE it will clean that stuff up... I don't mind the popping and love the flames, but that's just me.
PCV, quick shifter, stock gearing,
fly's out, custom garrett gt28 stage1 turbo, JE pistons, 625cc inj, MTC lock up clutch,1:1 fuel pressure regulator...
iTameBikes
posted March 13, 2013 06:52 PM
Honestly I like it too lol. Im not sure if it spits fire but I'll ask the zuk and yam riders if they noticed it while tryna catch up.
frEEk
posted March 13, 2013 07:22 PM
I've always heard that is the result of it running too rich.
posted March 13, 2013 08:11 PM
iTameBikes, search tool may help you with this specific problem. Its been discussed in detail
CajunBoyz
posted March 14, 2013 02:53 AM
I REALLY wish Guhl would take care of this in the ECU,, i & a few others Have asked him many times.......
izmuk
09 no flies,pvc,muzzy,low.long
posted March 14, 2013 06:41 AM
everything iv read on this points to lean not rich
BobC
posted March 14, 2013 07:01 AM        Edited By: BobC on 14 Mar 2013 15:06
The cure for decel popping is usually to block off or remove the pair valve or seconday air system.
You can buy a kit for this, anything from a $2 cap to a $65 set of plates, depending on which bike.
http://www.brocksperformance.com/Exhaust-Accessories+C10.aspx
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
CajunBoyz
posted March 14, 2013 12:27 PM
I have mine SEALED plugged on air box, & SEALED cap/plug @ the valve(electrical connector still plugged)
frEEk
posted March 14, 2013 12:53 PM
i musta misinterpreted what you were describing. thought i saw mention of flames out the backside on decel. i have a good case of that and it is definitely rich. but i can certainly imagine different scenarios.
LAB3
posted March 15, 2013 10:41 PM
For those of you that like the flames just remember the packing in the silencer will burn out must faster.
I purchased Ivans TRE when I had my 2007 ZX-14. I did not like hearing the back fire with the secondary flies out.
st8 gettin it
crazy azz whiteboy
posted March 16, 2013 02:29 AM
Don't buy a TRE its a waste of money. Flames and loud loping are cool. Kawasaki's are known for this. I have a new E85 tune and mine doesn't pop anymore.
carabuser
posted March 16, 2013 09:02 AM
Does a reflash of the ECU help with the pop on 2012 ?
CajunBoyz
posted March 16, 2013 10:38 AM
yes he made a few adj for the minor pop on the 14R's,, but I & a few others has asked him a few times to try & look into taking care of this decel pop on the early model 14's,,, Never happened.....
Bikemoneyman
posted March 17, 2013 06:11 AM
I have the Ivans block off plates.No more popping.
Son dying ain't much of a living from The Outlaw Josey Wales
CajunBoyz
posted March 17, 2013 06:22 AM
Does the Ivans block off plates come with & electricalplug to plug into the electrical connector that was disconnected from the valve?
posted March 17, 2013 08:56 AM
Osr has the block off plates. Great people to deal with
Bikemoneyman
posted March 17, 2013 02:10 PM        Edited By: Bikemoneyman on 17 Mar 2013 22:11
He has the connection on the more expensive kit.I didn't see it to after I bought mine but after 2000 miles no codes or problems.The other kit from Ivan was less then 10 bucks more at 58cycle.com.It was a bitch getting that junk out the way but it's clean looking now.
Bikemoneyman
posted March 18, 2013 12:43 PM
Just checked.The kit with the electrical connection is $55.
quikgix
posted March 18, 2013 04:01 PM
I have a map for 06-07 if thats the year you have, if you want to try it out. Mine doesn't pop and I don't have Ivan's TRE deal.
1352cc 8.39@159mph on motor cant wait to spray this bitch
0.29704904556274 seconds processing time
