BIKELAND > FORUMS > ZX-14.com > Thread: spark plug time... NEW TOPIC NEW POLL POST REPLY
lucassm
lucassm
posted March 02, 2013 10:55 AM
spark plug time...
well this year I have to bite the bullet and put plugs in my 14. So to avoid a trip to the stealership im gonna try the plugs myself. So are there any tips or tricks that i might need to know?
3000psi and falling
posted March 02, 2013 01:04 PM
Inspect the rubber boot inside of the spark plug tool, make sure its true and straight. I and another have had them go sideways and drop a plastic clip down and wedge beside the spark plug. Major pain to remove.
You can get the oem plugs from napa, advanced and? For about 9 bucks or so each.
Not as hard of a job as you might think.
If you need to adjust the gap on your new plugs, use a gap tool, dont pry between the ground strap and electrode (may snap off).. I think the gap is .080 - .090mm
Meangreen14
posted March 02, 2013 02:08 PM
Defiantly use the spark plug tool In your trunk once u get everything out of your way it's Pritty simple, but you will definetly ask yourself why Kaw had to invent this stupid frame that goes over the Engine & will probly cuss a couple times but you'll get it. While your in there take that stupid rubber cover of the engine..
PCV, quick shifter, stock gearing,
fly's out, custom garrett gt28 stage1 turbo, JE pistons, 625cc inj, MTC lock up clutch,1:1 fuel pressure regulator...
joseph702
posted March 02, 2013 02:49 PM
Ya with that tool and a magnet to get plugs out if they stick in there , I put tool in ad used a rachet wrench on the top and on the left hand side of bike take out the one plug and take rest off on the right side .
lucassm
lucassm
posted March 08, 2013 02:22 PM
Sounds like this is gonna be a blast lol. Thanks for the advice guys.
Lsantana954
posted March 08, 2013 08:26 PM
depends on weather you have large hands, on my 07 it was pretty easy(i wear a medium in gloves). I just used a 3/8 ratchet with a 3" extension spark plug socket and magnet. i would attach the socket to the extension and drop in and made sure it went onto the plug then attached the ratchet. once it was loosened all the way i would dismantle in reverse and use the magnet to fish out the plugs. The NGK plugs are already pre-gapped so no need to set the gap on em.
Also i dont know if this effects anything but once you have the coil sticks removed look closely on top of the cylinder head cover and youll see a line, the manual states that when you install the sticks that the connector should be lined up with that line.
'12 Gully Blue ZX14
-PCV/Guhl ECU/Blue CT Meg/<0 Alyson Oil/+8 Evil Arm/+1 Rear Sprocket
'07 Acura TL-S
'87 Buick Grand National
0.36186790466309 seconds processing time
