BIKELAND > FORUMS > ZX-14.com > Thread: need help again NEW TOPIC NEW POLL POST REPLY
colt
if u aint first your last
posted February 26, 2013 09:10 PM
need help again
When I dump clutch from a dead stop I feel a slip like a gear I can dump it from and other gear or any first from any speed only from dead stop has new clutch feels like grinding do clutch basket go bad
colt
posted February 26, 2013 10:04 PM
Would take to shop just don't see the dumping clutch at 3500 from dead stop to see what I'm talking about lol
Seno
BANNED FOR LIFE!
posted February 27, 2013 06:31 AM
When you say it has new clutch, are you referring to fibers, metals & springs? Or just fibers?
colt
posted February 27, 2013 07:22 AM
Full kit from barnet
Viper
posted February 27, 2013 08:40 AM
Probably wanna take that kit out and throw it in the trash.
2012 ZX14R SE
joel787
posted February 27, 2013 09:54 AM
You say the brand new clutch is slipping?
colt
posted February 27, 2013 10:08 AM
It's not a sliping I feel a clunk off the line
colt
posted February 27, 2013 10:15 AM
It just started been about a 1000 miles
joel787
posted February 27, 2013 12:51 PM
it only clunks on first?
colt
posted February 27, 2013 06:00 PM
Yea and off the line if u get rolling 3-4 mph and dump it it don't
joel787
posted February 28, 2013 06:52 AM
Im thinking The clutches might be sticking, or the lever is set too close..
zixxer14
Damn that was Quick
posted February 28, 2013 08:20 AM        Edited By: zixxer14 on 28 Feb 2013 16:22
Bleed the clutch line & check the resevoir level as a start, then think about inside, look for indents in the basket from the clutch plate tabs, make sure the stack height is correct & plates in correct order, no binding when released, springs seated right.
Seno
BANNED FOR LIFE!
posted February 28, 2013 12:30 PM
+1 Bleed the clutch. Also make sure the last friction pad is over 1 notch when you re-install. There was a reason they did that..... Original levers? If not make sure the plunger is seated fully into the lever cam, my 07 acted funny with Pazzo’s when it was not seated in fully…. Took me forever to figure that one out.
colt
posted February 28, 2013 08:02 PM
Stock lever clutch was installed right like I said it started a 1000 miles or so in to the clutch I dumped it from a 5 mph roll and no cluunk smoked tire down street
Hellmutt
posted March 03, 2013 07:18 AM
Ok, so you're slamming the clutch at high revs to break the rear loose doing burnouts and you're worried about a little 1st gear clunk?
colt
posted March 03, 2013 06:53 PM
Some tire spin I'm launching like when I race
zixxer14
Damn that was Quick
posted March 03, 2013 07:22 PM
Is your chain loose or worn out sprockets so it's jumping teeth?
colt
posted March 03, 2013 08:15 PM
Nope all brand new less than 300 miles
0.33620500564575 seconds processing time
