BIKELAND > FORUMS > ZX-14.com > Thread: Front fork NEW TOPIC NEW POLL POST REPLY
riaansh
posted February 23, 2013 12:56 PM
Front fork
When I received my bike 14r [2012] I noted that the top part of the front fork was flush with the top bracket. In the manual it says the fork must be 21.5 mm above the bracket.
Does any of you experienced the same problem?
Must say I experienced a lightness at high speed runs so this could be part of the problem.
zx12mark
posted February 23, 2013 03:26 PM
set it to factory specs and rrrrrrrrriiiiiiiidddddddddeeeeeeeeeee.
Lou_ZX12R
One Day at a Time
posted February 24, 2013 09:56 AM
, i haven't noticed if mine it's set that way, i will need to take a look. did find this out while trying to see why it was light or some other reason?
2000 ZX12R 40shot
2012 ZX14R
2009 Concours 14
riaansh
posted February 24, 2013 11:47 AM
I have googled at a few photo's of 14r and noted some also flush mounted with the top clamps. There is some that is set to some kind of spec.
How many of you have a flush mount and how many has been adjusted?
The lighness of the steering at high speed is not nescessarily bad handling, but feels bit strange.
I'm not certain of the adjustment as the bike comes half assembled from the facotry. So did the dealer change the setting or did the factory assembled it like this.
If it is the latter why wasn't it adjusted as the service/workshop manual says.
I noted on another forum that they said it should be adjusted to 21.5 mm and i knew mine was flush mounted to answer your question - Lou zx12r
BobC
posted February 25, 2013 06:24 AM
Perhaps the quoted 21.5mm is measured before the handlebar is bolted onto the top yoke?
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
riaansh
posted February 25, 2013 12:31 PM
I'm not sure how it's measured now. On Brock's forum they do a 30mm adjustment from the top of the fork tube to the clamp where the one bolt is positioned [the front bolt].
0.24363303184509 seconds processing time
