BIKELAND > FORUMS > ZX-14.com > Thread: Check Engine light on after mods NEW TOPIC NEW POLL POST REPLY
BlackMagic14
posted February 22, 2013 09:43 PM
Pulled the fairings, undid the two hoses that run along side the right ram air tube into the little box inside the right fairing. Installed, exhaust,kickstand,and Pulse 3 battery. When I cranked it back up the check engine light was on. I thought maybe it was the two small hoses I disconnected so I unplugged the battery for 15 minutes put fairing back on the right side reinstalled the two hoses and installed the power commander and the check engine light is still on. I can't think of anything we did that could have caused except maybe the battery. Any ideas?
PS the bike seems to run fine
MotoCycho
posted February 22, 2013 11:15 PM
Gotta be some code(s). What year bike?
Seno
BANNED FOR LIFE!
posted February 23, 2013 03:07 AM
Mine threw some codes after unplugging some electrical connections that I forgot to reconnect....
BobC
posted February 23, 2013 05:25 AM        Edited By: BobC on 23 Feb 2013 13:28
On my bike it was removing the lambda sensor that did it. Went off again when I reinstalled sensor and O2 eliminator on the Brock CT system. However, mine's a UK bike. Don't think yours is quite the same?
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
BlackMagic14
posted February 23, 2013 06:40 AM
It's a 2012. Do you guys think it could be something with the battery? I am 90% sure I reconnected everything
BlackMagic14
posted February 23, 2013 06:41 AM
Also if I take it to the stealer ship can they check the codes on it?
zx13r
Capt-America
posted February 23, 2013 03:30 PM
Has to do with the DFI page 3-29 in manual. it's remembering the code from the idle vacuum hose being on hooked and the key turned on.
Sposored By:
Kawasaki Sports Center
ShoTime Graphics.com
BlackMagic14
posted February 23, 2013 07:41 PM
How do I clear the code?
BlackMagic14
posted February 23, 2013 08:16 PM
Also how do I get it to display the codes?
zx13r
Capt-America
posted February 23, 2013 08:25 PM
Turn key on and hold select for two seconds
Sposored By:
BlackMagic14
posted February 23, 2013 09:28 PM
All that does for me is bring up the menu. English/francais
BlackMagic14
posted February 23, 2013 09:29 PM
I wonder how you reset the check engine light?
GREYHOUNDMOSES
posted February 24, 2013 05:17 AM
Not tried it, but I believe removing power to the ECU clears stored codes.
Take out the ECU fuse (in the tail under the seat) and leave it out for around 15 minutes.
Replace the fuse before turning the ignition back on.
Hope this helps.
posted February 24, 2013 06:06 AM
I would think disconnecting the battery would reset it.
alexmastiff
posted July 09, 2013 02:39 AM
Hi.a have straight question for you,looking out for help.zzr 1400 ownwer,european model.09'.i have installed a yoshi full exhaust that drilled before so as to keep the 12mm o2 sensor.i also pluged-in line- o2 optimizer 76125017.no pcv's no nothin;question is (from your experince) can the bike be ridden this way?or to remove 76125017?
regards
Alex
Lsantana954
posted July 09, 2013 02:37 PM
mine threw a code when i tried to leave the air switching valve removed, i then plugged it back in and the check engine light went away after a few cycles
'12 Gully Blue ZX14
-PCV/Guhl ECU/Blue CT Meg/<0 Alyson Oil/+8 Evil Arm/+1 Rear Sprocket
'07 Acura TL-S
'87 Buick Grand National
thutch26
thutch26
posted July 10, 2013 01:19 AM
yeah mine too... the pair valve needs to be plugged in.. i tried elimiinating mine yesterday like on my gen1but while putting on my pc5 and pair valve blockoffs it threw a code when i started it. and the engine light was on.. dont know if yours is unplugged or not but check it out
Hollywood Slim
posted March 26, 2014 04:43 PM
I installed my new Brocks Alien Head 2 exhaust on my 2012 ZX14. I followed all instructions and made sure that everything is back where it needs to be. I have double checked all screws and fairings. After the second time I started the bike my engine light came on. Can anyone help me? I have tried to hold the select button, but the only thing it does is takes me to English or French language select option. I know that it is something simple, so any help would be much appreciated. Oh yeah, by the way I did put the red cap and connect the hose to it as instructed by Brocks Performance.
BlackMagic14
posted March 26, 2014 06:20 PM
Do you have the little tank in the right mid fairing? And did you reconnect those two hoses to it if so?
Hollywood Slim
posted March 26, 2014 06:44 PM
I am not sure what tank are you talking about, but the only hose I have touched was the one connected to the air box. I had to plug that hole and the attach it to the red cup provided.
Hollywood Slim
posted March 26, 2014 07:02 PM        Edited By: Hollywood Slim on 27 Mar 2014 03:11
I just looked at it. It is called the PAIR block off.
0.24159407615662 seconds processing time
