BIKELAND > FORUMS > ZX-14.com > Thread: Turbo Gearing ? NEW TOPIC NEW POLL POST REPLY
1qwikzx
posted January 23, 2013 09:50 PM
Turbo Gearing ?
What's up guys, I've decided to go turbo and was looking for suggestions for gearing. currently running -1/+2 on stock engine and +6" arm. Here's what I'm working with;
Stock engine
+6" arm
5-6 psi of boost
250 lb rider with gear
Looking for 1/4 mile gearing
Meangreen14
posted January 23, 2013 11:29 PM
Lower the compression or you'll eventually be replacing the pistons, at least pull some timing and run her fat under boost, but just save time & money & get some turbo pistons..
PCV, quick shifter, stock gearing,
fly's out, custom garrett gt28 stage1 turbo, JE pistons, 625cc inj, MTC lock up clutch,1:1 fuel pressure regulator...
kawasakijockey
posted January 24, 2013 03:52 AM
About the same weight as you but a 10in arm. At 5lbs boost I run 16/44.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
0.27385997772217 seconds processing time
