BIKELAND > FORUMS > ZX-14.com > Thread: PC Quickshifter setup information ? NEW TOPIC NEW POLL POST REPLY
Kawi9
posted December 30, 2012 06:44 AM
I want to fit a quickshifter from power commander on a ZX14 06 and i want to know what is your setup ? Shift sensor, length of rod etc. Show me your setup pic !
Also, what is your setting m/s ?
Thanks.
Kawi9
Kawi9
posted January 05, 2013 11:38 AM
Nobody !
Come on guys. I already saw some guys have quickshifter on her ZX14.
I need info for to buy and fit the quickshifter.
ama573
posted January 05, 2013 01:34 PM        Edited By: ama573 on 5 Jan 2013 21:35
I think I set the gear 2 shift to 80 ms and left the others at the default of 65 ms.
Here is how I installed it.
ama573
posted January 05, 2013 01:40 PM
You need to tap your speed sensor to connect to the power commander if you didn't already do that when you installed your power commander.
Kawi9
posted January 06, 2013 07:47 AM
Nice !
Could you tell me what is the lenght of your rods and the rods are available from Dynojet ? If yes what is the number part ?
How long you have this setup and any problems ?
Thank.
ama573
posted January 06, 2013 09:45 AM
The dynojet p/n was 4-116. The box says for PCV so it could be a different p/n if you have a PCIII. The rods are part of the quickshifter and are threaded for length adjustment. No issues with it yet but I have only been using it for about 6 months.
Kawi9
posted January 07, 2013 08:43 AM
Ok Thanks.
I have PCIII USB. Have you cut the upper rod ?
ama573
posted January 07, 2013 04:19 PM
no, that's the stock length upper rod.
0.42132687568665 seconds processing time
