BIKELAND > FORUMS > ZX-14.com > Thread: What gearing are you guys with extended 14r's having luck with at the strip? NEW TOPIC NEW POLL POST REPLY
rACeRs
posted December 09, 2012 08:52 AM
I'll be adding some wheelbase soon and wondering what a good starting point would be. I'm about 235 suited now, but working on that.
And I've always geared my extended bikes to finish in the top of 5th, would I have better results gearing to use all 6 gears? Or is that extra shift a waste of time?
9.1 @ 149 w/ 1.57 60' SWB
Wheelie
Old Man
posted December 09, 2012 12:05 PM        Edited By: Wheelie on 9 Dec 2012 21:20
I like using all 6 gears in the 1/4 mile. 69" 225 lb suited.
wee
rACeRs
posted December 09, 2012 03:41 PM
what gearing are you using, and whats your best pass break down look like?
thanks
Wheelie
Old Man
posted December 09, 2012 03:47 PM
thanks
Good air I had to change the gearing from 17-51 to 17-49, ran out of gear on a 8.75@154mph pass,
wee
rACeRs
posted December 09, 2012 05:10 PM
nice, thats moving. was the 8.7 pass with the 49 on?
joseph702
posted December 09, 2012 06:37 PM
I went 5 in over and went 16-41 and tried 16-43 went back to 16-41
Wheelie
Old Man
posted December 09, 2012 06:42 PM
how much do you weigh?
wee
rACeRs
posted December 10, 2012 05:11 PM
I didnt know there were so few stretched 14r's that drag race
posted December 10, 2012 05:39 PM        Edited By: smokinZX14 on 11 Dec 2012 01:39
That is not problem ... Lots of zx14 drag racers but most don't weight 225 pounds .. What works for me at 150 pounds will not work for you ... I use 16/44 or 16/43 .. You can try that but i think you will need something like 16/45 or 46 at your weight .. The thing is you will not know till you try it ... I have lots of extra gears laying around that didn't work...
rACeRs
posted December 10, 2012 06:19 PM
thanks for the reply, Im just looking for a good starting point. Im sure Ill have to try a few different setups to get it where I need to be.
with your gearing are you finishing in 5th?
posted December 10, 2012 06:45 PM        Edited By: smokinZX14 on 11 Dec 2012 02:49
With 16/43 i shift 6th gear right after the finish line . That is with using my shorter 008 slick .. With the shinko 003 ultra soft ( a bit taller tire ) i can use the 16/44 and run 5th to the finsh line ..
edszx14
posted December 11, 2012 06:14 AM
Nice video. great run. Wish I could do that.
Ed
Beondwacko
posted December 11, 2012 05:02 PM
Aw hell............ I used to do that all the time! Just a bunch slower that's all!!!!
posted December 11, 2012 07:11 PM
LOL ..
BIKELAND > FORUMS > ZX-14.com > Thread: What gearing are you guys with extended 14r\'s having luck with at the strip? NEW TOPIC NEW POLL POST REPLY
0.3110089302063 seconds processing time
