BIKELAND > FORUMS > ZX-14.com > Thread: Muzzys Bonneville Pro issue NEW TOPIC NEW POLL POST REPLY
ama573
posted November 21, 2012 12:01 PM
I'm have a Muzzys Bonneville Pro on my 2008 ZX14.
Lately my speedometer has been having an issue. It has dropping from the correct speed to zero, sometimes it stays at zero for a while, then works again, sometimes it bounces back and forth between the correct speed and zero, other times it just drops 10-20 miles below the correct speed and bounces back to the correct speed.
I checked all of the connections in the associated with the speedometer and the issue persisted.
I disconnected the Bonneville Pro and the speedometer has been working correctly, so it looks like the issue is caused by the Bonneville Pro.
Has anyone else seen something like this?
Rich
Just havin' fun!!
posted November 23, 2012 07:09 AM
Yeah. I can be riding along and my speedo just drops to zero and then returns to normal speed. It only does it once in a while. All connections seem OK. I figured it was the Bonneville Pro. I didn't do anything to try and fix it though.
07 Green and Black, How fast is fast?
203 for now. Limited $$ = limited HP.
  Ignore this member    Click here to visit Rich's homepage.
Seno
BANNED FOR LIFE!
posted November 24, 2012 08:07 PM
Check to make sure you have a good ground, also check that connectors are seated fully
posted November 25, 2012 12:38 PM
My speedohealer acted this way once when it got wet and fine again once dried out
0.42784309387207 seconds processing time
