BIKELAND > FORUMS > ZX-14.com > Thread: Auto tune NEW TOPIC NEW POLL POST REPLY
riaansh
posted November 06, 2012 11:59 AM
Auto tune
Since I'm from South Africa I installed the auto tune. It was used in conjuction with Brock's goodies. Our fuel quality is not the same as what the map was tuned for, so I did the auto tune installation.
Before the a/t seat of pants feeling was as follow: First gear power wheelie with +- half throttle opening [41 rear sprocket], second gear not always power wheelies, depends on how i opened the throttle I guess. Top speed revs in top gear in a 2km run was 10900.
After the auto tune installation: First gear the wheel lifts much like with the standard sprocket setup. Second gear power wheelies easily, with an aggressive run from first gear it comes up hard. Top speed run now in the same area and distance it runs to at least 11400 revs now.
So for our conditions this auto tune realy works fine. I will recommend it also for someone that does not have a reputable tuner in their area.
cliffrandall
posted November 06, 2012 02:14 PM
How exciting Ria, thanks for the note. What A/F ratio did you set it too?
Cliff
zx12mark
posted November 06, 2012 03:05 PM
How are you verse`s sea level where your making your runs.
riaansh
posted November 06, 2012 10:15 PM
Gents this is just my experience with regard to the auto tune. A/F ratio 13.2 look in Brocks Q/A section. Sea level run on a strech of road close to me. No official timing. Unfortunately we don't realy have top speed events where I stay. Brock's street map as base. You need to read the section for info.
0.2129499912262 seconds processing time
