BIKELAND > FORUMS > ZX-14.com > Thread: Grrrrrrrrrrrrrr ... Rivet master links ... NEW TOPIC NEW POLL POST REPLY
posted October 26, 2012 04:38 PM
Over the years i have been working on bikes i have done 100s of rivet type links but this one is kicking my ass ..
I needed to change the gears on my ZX14R and to do so i needed to remove a few links of chain ...I had one EK ZZZ master link in stock .. The day before i just did one on Ryans new EK ZZZ chain so i already had the chain tool out and ready to do my bike .. Everything went fine till i tried to spread the rivet pin and pop ! I split the link pin ... Now i have to order a new master link ... I order two master links so i'll have a spare ...They come in and i go to install one of them and it splits the rivet pin again ...Ok ...I get the spare out and split that one also ... Ok what the hell is going on here ? Maybe my tool is bad , i have used it for years and 100s of Master links so maybe it's just worn out .. So i order new replacement parts for my chain tool and two more new Master links ... They show up today , so i go to install the master link .. One spreads just fine and i'm like cool !!! One down one to go ... I just start to spread the other pin and POP !!!! It split !!! ... I'm doing this by hand , no wrenches or power tools , just my hands.. Till now i have never had this happen ... I have the one spare Master link left but i need it for my other bike that has a ZZZ chain .. I really like running these EK ZZZ chains on my bike but i can't keep screwing up Master Links .. So here i sit on the throne , came to shit and only farted ...
1badzx12r
posted October 26, 2012 04:42 PM        Edited By: 1badzx12r on 27 Oct 2012 00:49
I'VE never ruin a master link ..can't help you pops ..i flare mine with 1 the cheap ass harbor freight chain pin removal tools .http://www.harborfreight.com/heavy-duty-chain-breaker-66488.html
posted October 26, 2012 04:51 PM
Maybe that what i need , a cheap assed tool ... I do have one of them at the shop that we have never used .. Damn sure can't be any worse ...
1badzx12r
posted October 26, 2012 04:54 PM        Edited By: 1badzx12r on 27 Oct 2012 00:55
put a bolt in the tool on the back side so it don't push your chain pin out ..and don't get stupid tight on the tool or it will spread apart ..it don't take much of a flare to lock the master link down ..
posted October 26, 2012 04:59 PM
I'll give it a shot .... Thanks ..
kawasakijockey
posted October 26, 2012 05:44 PM
On the EK rivet links you have to go slow and only flare them .012 or they will split.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted October 26, 2012 05:52 PM
I didn't even get to that number and it split ..
biggmoinc
posted October 26, 2012 07:12 PM
I just split one one a gold zzz rivet link the other day, weird thing is it just didn't split, damn pin just crumbled! Maybe not a coincidence?
biggmo@aol.com
joseph702
posted October 26, 2012 07:13 PM
I use my hydro break flare tool and works mint every time. I know with brake line power stealing lines and shit when bit gets worn it splits the ends .
joseph702
posted October 26, 2012 07:14 PM
quikgix
posted October 26, 2012 07:40 PM
I use a clip type link. F@€k it
1352cc 8.39@159mph on motor cant wait to spray this bitch
posted October 26, 2012 07:42 PM
The last one i did today split in half and was completely gone .. In the passed i would really have to crank down on them to flare them and they never split or broke .. Maybe they changed the way they make them ? or had a bad batch.. Or maybe EK farmed them out to China to be made .. Sure got me thinking of going back to the EK DRZ2 Drag chain and using the clip link like i did on my two other ZX14s .. A little RTV on the clip and never had one single problem .. Not a good chain for the street but it's a great drag chain ..
posted October 26, 2012 07:45 PM        Edited By: smokinZX14 on 27 Oct 2012 03:53
They don't make a clip type link for the 530 ZZZ chain or i would ..They make one for the 520 ZZZ chain but not the 530 ZZZ ...
quikgix
posted October 26, 2012 07:51 PM
Yeah im using a DR2 drag chain. In the past ive used rivet style master links without any issues
posted October 26, 2012 07:54 PM        Edited By: smokinZX14 on 27 Oct 2012 03:55
With your DR2 chain what lube are you using ?
madnessracing
Vmax and Busa Beater
posted October 26, 2012 08:00 PM
Things happen Smokin dont let things like that ruin your day
Shorty's Performance
Team Madness Racing
quikgix
posted October 26, 2012 08:10 PM
I use Amsoil chain lube, i clean then heat the chain with a butane torch then lightly lube each link. I dont like that sh!t flinging everywhere.
posted October 26, 2012 08:12 PM
zixxer14
Damn that was Quick
posted October 26, 2012 08:41 PM
Sounds like there may be a bad batch of links out there. May be that they have the wrong heat treatment making them too brittle.
blackbullet76
posted October 26, 2012 10:24 PM
I have a clip master link on my 530, but I think I have the X-ring chain.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
posted October 27, 2012 05:33 AM
Lee, I have had the same issue recently, I use a Regina chain breaker/ riveter.
I thinbk they use cheap metal as of late because I never had issue with my drzzz back in 06.
Likely its metalurgy but they would never admit it anyway...
zixxer14
Damn that was Quick
posted October 27, 2012 06:49 AM
China Attacks again!
quick6
posted October 27, 2012 07:26 AM
i use a clip style on my zzz. never had a problem. just went down to the local motorcycle shop and dugg thru their o ring clip style links till i found one .
2006 zx14, fully dressed and sliding(Charlie Sheen)
SteddyTeddy
posted October 27, 2012 07:28 AM
Like I said on the phone, if you have the little Motion Pro tool, its a fucking toy! Was never so glad to get rid of mine. Split links all the time! I know use one like this and it works10x better.
http://store.schnitzracing.com/rk-excel-chain-breaker-press-fit-rivet-tool/
posted October 27, 2012 10:32 AM
hate to bust your bubble but that is the same tool i'm using ..
0.24237895011902 seconds processing time
