BIKELAND > FORUMS > ZX-14.com > Thread: 2x4 motor might buy worth it? NEW TOPIC NEW POLL POST REPLY
joseph702
posted October 14, 2012 06:39 AM
guy has a 2x4 motor for sale $5,500, its a 2x4 motor with corillo rods je pistons ,ape studs , carpenter head stage 3 with cams , nos cut tranny,mtc lock up clutch only has 2 dyno runs at 238-240 hp.
but what im worried is its a dry block. iv never dealt with a dry sump motor. is it worth the money?
posted October 14, 2012 06:52 AM
Dry sump or dry block?
joseph702
posted October 14, 2012 07:11 AM
dry block , just asked him about it , its a dry block not coolant
posted October 14, 2012 07:25 AM
Ok, so what are you planning to use it for...besides drag racing?
joseph702
posted October 14, 2012 07:32 AM
id like to do racing and lsr. id take the motor apart and put in my cases but its a 06 mine is a 09 and cranks are diffrent arnt they ?
posted October 14, 2012 08:32 AM        Edited By: Shane661 on 14 Oct 2012 16:32
The crank gear is different, and basket gear, but all else will work, afaik? Meaning you can just swap all of the parts....and bore your cases for the pistons. But for that effort, no...it is not worth it, imo.
joseph702
posted October 14, 2012 08:47 AM
the head cams and every thing makes me want it but ends being a huge pain int he ass. i guess if he parted it out id buy head and rods. what are carillo rods worth used?
posted October 14, 2012 08:57 AM
If you have to replace the rod bolts they are like $30+ each or something crazy like that. If the bushings are worn, more expense to rebush. It all depends on the condition.
Halvefast
posted October 14, 2012 11:24 AM
Plus those are stroker rods, depending on what you are looking to do, you would need the crank too.
ECTA Ohio Mile 195.132mph
joseph702
posted October 14, 2012 12:20 PM
There stock lenth rods
posted October 14, 2012 02:54 PM
so is the block filled or they just running it dry?
joseph702
posted October 14, 2012 03:13 PM
Filled
0.21727895736694 seconds processing time
