BIKELAND > FORUMS > ZX-14.com > Thread: wiring kill box straight to ECU NEW TOPIC NEW POLL POST REPLY
toledoUPSguy
An old guy with a new toy
posted October 07, 2012 09:11 PM
There have been some threads with our very respected members who are wiring their MPS kill box straight to the ECU. There aren't any pictures of the installations. So I have a few questions I hope to get answers to.
1) with the plug and play Schnitz coil wiring harness are we doing this strictly to reduce excess wiring? There has to be some reason to cut into a perfectly good harness.
2) I've noticed soldering has been mentioned. Are you wiring the brown wires to the pin that is in the socket or are you actually cutting the wires and soldering the 3 wire ends back together?
Anybody have a pic or two would be great.
Thanks again for all the help.
The man on top of the mountain didn't fall there.
2014 ZX14r in nuclear sunset orange and black
biggmoinc
posted October 08, 2012 06:14 AM
http://www.bikeland.org/board/viewthread.php?FID=27&TID=65470&set_time=
biggmo@aol.com
toledoUPSguy
posted October 08, 2012 01:03 PM
i've read that thread more than once. it peaked my interest since Lee went from using the plug n play schnitz coil harness (which the used stuff I bought has) to hard wiring the ECU but it doesn't answer either question.
i've search for every thread i can find that mentions ecu wiring and not one of them has a picture of their splices.
Wheelie
Old Man
posted October 08, 2012 01:51 PM
Just strip back about a half inch of the insulation, wrap the mps wire around the ecu wire and soldier it, tape it, then when all four wires are soldiered and taped, wrap tape around all of them making it look like the factory wiring.
wee
zx13r
Capt-America
posted October 08, 2012 02:03 PM
Sposored By:
Kawasaki Sports Center
ShoTime Graphics.com
toledoUPSguy
posted October 08, 2012 02:24 PM
Thanks guys, I appreciate the help.
Lucky14
posted October 08, 2012 02:25 PM
wee
Exactly, with these specfics:
1. Do NOT cut the wires going to the ECU.
2. Stay 2 or 3 inches away from the ECU so the heat from the soldering doesn't hurt the ECU.
0.26561498641968 seconds processing time
