BIKELAND > FORUMS > ZX-14.com > Thread: 14r rear brakes loud high pitch only 900 miles any ideas? NEW TOPIC NEW POLL POST REPLY
speedyme
posted October 03, 2012 04:35 PM        Edited By: speedyme on 4 Oct 2012 00:36
i have a 14r with only 900 or so miles and when im on the rear brakes to much i guess they get too hot and make a high pitch squelling, anybody else have this problem? never once on my 09 14 did they squell. should i take it to the dealer or just get better pads? its really loud and embarrasing, any input would be appreciated, thanks
speedy
  Ignore this member    Click here to visit speedyme's homepage.
venomous_zx
2012 14r - low and long-
posted October 03, 2012 05:59 PM
is it a constant squeal while applying rear brake? or is does it start,stop,start? how long have you had this problem?
sensei
speedyme
posted October 03, 2012 07:03 PM
its been doing it since about 250 miles and on off kinda thing but especially when hot , loud!
speedy
zx12mark
posted October 03, 2012 07:13 PM
thats weird. my 2000 zx12r with ebc kevlar pads squeels like a little busa bitch after i beat him.
venomous_zx
posted October 04, 2012 01:58 AM
Maybe the pads crystalized..... not sure if the stock pads will do that. How does the rotor feel/look? Loss of breaking power?
sensei
Bently
2012 14r In Blue and no Mods!
posted October 04, 2012 06:15 AM
With 2000 miles on mine I don't think I've ever used the rear brake.sounds like you're using the rear brake for most of you're stopping power. Which probably overheated you're pads and glazed them.most of you're braking should come from the front brakes.
venomous_zx
posted October 04, 2012 06:46 AM
what bently said... i was looking for that word,glazed.. lol. instead i used crystalized. you might want to start braking with rear brake then when the weight of the bike moves forward then use your front brakes and release back break or use back break in moderation with the front.... remove your old pads and inspect them.. they will probably feel smooth and hard if they are glazed... compared to normal pads that arent glazed.
sensei
speedyme
posted October 04, 2012 07:17 AM        Edited By: speedyme on 4 Oct 2012 15:18
I've been riding for almost 30 years so I don't think I'm using to much rear
Brakes. I use mostly front but when I do use the rear to hard or too much
It squeals. It's the first bike I've owned that's done this so I'm sure it's not me
speedy
venomous_zx
posted October 04, 2012 07:31 AM
in that case inspect your pads/rotors.... its either one of those. highly doubt its the caliper....
sensei
Ninjawarrior1244
posted October 04, 2012 07:38 AM
With such low mileage recommend you consider taking it to dealer for inspection replacement of rear brake pads..should not squeak like that being brand new....sounds like defective pads or you overheated the rear disc.
Speed is fine...but accuracy is Deadly!
venomous_zx
posted October 04, 2012 07:44 AM
i dont think brake pads are covered in warranty... he will have to pay out of pocket... good thing they are not expensive..... if rotor overheated then it would tend to start warping.... personally i wouldnt take the bike in to dealership without replacing the pads. they are going to charge that high hourly rate. at that point your better off replacing the pads yourself. if for some reasion you do that and still have that noise then its prolly the rotor.. and now you got s extra set of pads for the future.
sensei
Kawifast
posted October 04, 2012 08:10 AM
They all do it Just ask your dealer
2012 Kawasaki ZX14-R
2012 BMW S1000RR
2012 BMW K1600GT
speedyme
posted October 04, 2012 10:10 AM        Edited By: speedyme on 4 Oct 2012 18:11
thanks everyone, i think i will try replacing pads with some good ones, just wanted some input first, thanks!!!
speedy
epd345
posted October 04, 2012 12:09 PM
Just scuff up your rear rotor a little with sandpaper and drop in some new pads. They are like 25-30 bucks for a new set. Cheap safety insurance. BTW I also warped a Galfer Wave rear rotor on my 07. Galpher said they had never seen anything like and replaced it. I am also heavy on my rear brakes as I am not a lightweight and I like to practice panic stops occasionally which hammers the brakes hard.
speedyme
posted October 04, 2012 02:32 PM
""I like to practice panic stops occasionally which hammers the brakes hard. ""
Im glad to see someone else does this! i cant believe how many people dont use there rear brakes. thats crazy, i know they only account for only 25 30 percent but in an emergency that could mean the difference between hitting something or not, plus the front pads will last longer using front and rear every time
speedy
LeoVinceZX14
Thankfully...its paid for...
posted October 05, 2012 02:08 AM
speedyme:
Not having any problem with my rear (2,800 miles), BUT I use it routinely on twisty roads and in hard braking situations. In fact in a corner, often I only used the rear to..tweak my entry speed and not upset the front grip. Of course for maximum stopping the front probably has 70 odd % of the stopping power, but your not crazy using it bro.
Leo
'12 14R SE
PC V
Custom map
BMC filter
Leo Vince 4-2-1 w/ carbon can
Sato frame sliders
Supersprox 42T
Cox radiator guard
DID 530 X-ring chain.
venomous_zx
posted October 05, 2012 02:59 AM
I use both brake all the time. Its habit for me. I even use them in a turn.
sensei
0.22658205032349 seconds processing time
