BIKELAND > FORUMS > ZX-14.com > Thread: Personal Best! NEW TOPIC NEW POLL POST REPLY
Juice
posted September 30, 2012 06:49 PM
Personal Best!
I just got the nitrous set up on my 07 ZX14 and hoping for 8's this weekend....
Didn't quite get to the 8's but I did set my personal best, I think with more seat time and a better 60ft ill be there.
I was in the right lane and my # is 6006
Very Bad RT, and a Ok 60ft I guess (my normal 60ft times are 1.47 to 1.45)... Corrected air was 3500ft at the time of my run...
2007 Kawasaki Ninja ZX14 SE - 8.74 @ 150 MPH
joel787
posted September 30, 2012 06:53 PM
Congrats!
posted September 30, 2012 06:59 PM
You hit 1.45 60 you got your 8 second pass ..
babyninja
posted October 01, 2012 10:36 AM
Nice job Juice!
'10 ZX14
Brocks SM
PCV w/ Brocks map
'06 Busa
'98 ZX9R
750 H2
Wheelie
Old Man
posted October 01, 2012 10:43 AM
looking at both bikes a 3.87 330 will get the 8.
wee
MotoCycho
posted October 01, 2012 10:47 AM
Hey Juice,
If you don't mind me asking? What is your nitrous setup like? What size is your shot? What do you weigh and what is your wheelbase?
Juice
posted October 01, 2012 11:50 AM        Edited By: Juice on 1 Oct 2012 19:52
Hey Juice,
The bike is at 68.5" center of axle to center of axle... My gearing is -1 +4 (16, 45). Im right at 235 lbs suited...
The nitrous set up is kinda home made where thinking its around a 60 Shot... It's a wet kit that I drilled and tapped the heads right below the throttle bodies...
I'm using NOS Jets (20 nitrous 18 fuel) in each nozzle, tuned to 11.7 af with pc5 and auto tune.
MotoCycho
posted October 01, 2012 12:36 PM
Thanks Juice.
00Busa
Trying to go FASTER !
posted October 05, 2012 09:13 PM
60ft was decent, but 330 appears if you're not getting the throttle wide open soon enough !
'00 Busa / '06 14 /
IT AINT BRAGGING, IF YOU CAN BACK IT UP !
posted October 06, 2012 03:54 AM
+1
posted October 06, 2012 03:57 AM
Im going to suggest 1/8 SS lines. I know tons of guys run the poly lines, but i just feel better with something that wont ever melt. direct replacement for those poly lines, and easy enough to bend by hand (3/16 can be a bitch by hand)
Juice
posted October 06, 2012 03:49 PM        Edited By: Juice on 6 Oct 2012 23:55
Im full throttle at the same time i let the clutch out on the launch.
I didnt hit the nitrous till i shifted into 2nd gear... So that might be what your noticing...
I want to use ss lines but my solenoids and distribution blocks are in my battery box... So fitting the lines throught the small holes might be a little hard... Not to mention I dont think i could fit them in the #4 nozzle.... Coolant temp sensor is in the way....
0.3475661277771 seconds processing time
