BIKELAND > FORUMS > ZX-14.com > Thread: Tight chain or lose chain , what is faster? NEW TOPIC NEW POLL POST REPLY
posted September 20, 2012 07:21 PM
I heard that a lose chain is a fast chain .. I ran my best numbers and MPH with the tight chain .. I'm running a ZZZ and just love it .. I was running a DZR2 race chain on my gen 1 bikes but it takes a lot of work because it's a non 0ring chain .. I just hate cleaning and lubing chain every race day .. The ZZZ i just lube and run the snot out of it ... It seems to run the same numbers with less work .. So what do you guys like lose or tight ? Have you seen any difference in ETs or MPH having it tight or having it lose ?
JZX
posted September 20, 2012 07:52 PM
I like a little slack- also, shane should know, the land speed guys use some Teflon spray instead of chain lube. I use it, no problems.
06 ZX14 65"
Best 1/8 mile 5.68@126.4 on a 1.41 60'
Best 1/4 mile 8.87@152.7 on a 1.47 60'
posted September 20, 2012 07:58 PM
Hummm teflon , never tried that ..
Slo Moe
posted September 20, 2012 08:02 PM
Is that the teflon spray the bicycle guys use?
Riding hard and sloppy - the Johnny Gan way!
1badzx12r
posted September 20, 2012 08:13 PM
oh man
JZX
posted September 20, 2012 08:27 PM
I gotta find my can, but I figure those guys can do 200 with it, I'm good to go. used it on an o ring and non o ring chain.
06 ZX14 65"
BobC
posted September 20, 2012 11:25 PM        Edited By: BobC on 21 Sep 2012 10:19
Like this? Jack Frost at Santa Pod for the Hayabusa tenth birthday bash.
Look at the lower chain run !!!
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
smokinstorm
Old Drag Racer
posted September 21, 2012 06:37 AM
No matter how tight you have it at a standstill it'll still look like in the above pic on the launch. I know if we don't have the chain really tight it skips on the launch. Now we've got a 16 tooth front sprocket, a helluva lotta weight to get moving and a long wheelbase so I'm sure those are factors. 60's in the low 1.3's usually.
2009 Monster Edition ZX14
It's all stock I swear. Well...almost.
2005 Turbo Busa
2001 GSXR 1000
Looking for a 1985 GS1150E
Swiftkart
posted September 21, 2012 08:28 AM
The Moto GP guys chains have Teflon o-rings, very hard to get a hold of, I have a couple in size 415 & 520 I run on my RS125 & TZ250V powered superkarts, real trick stuff, been trying to get my GP contection to get me one in 530, no luck.
BLK ICE
posted September 21, 2012 11:00 AM        Edited By: BLK ICE on 21 Sep 2012 19:32
I set my chain as tight as I can (with the swing-arm parallel with the ground !), and the wheel still roll freely.
Have someone sit on the bike or adjust your lowering links until the swing-arm is parallel with the ground ( readjust lowering links back to your race setting afterwards).
Once parallel, tighten the chain snuggly.
Then, loosen the adjustment screws (a half a flat at a time) just until the wheel rolls freely.
I know this sounds time consuming, but it well result in free horsepower.
Chain lube:
Most chain lubes are sticky, resulting in increased rolling resistance.
I use WD40 and lube the chain about every 4 passes.
side note: If you don't already do so, and feel safe doing so; set your front tire to 50psi.
Again, time consuming, but I have seen several cases were bikes have gained more than 2mph by apllying all of these steps ZZZ and non-oring.
Hope this helps,
BLK ICE
greenbusa
posted September 21, 2012 11:52 AM
I agree with BLK ICE on the WD-40, thats all I use at the track and on the Dyno. Usually 2mph or more and as much as 3-4hp on the dyno, especially if the chain is dirty. On the dyno I'll get the drum rolling about 10mph and spray the hell out of the chain while holding a rag under the chain.
400+ hp daily driver
posted September 21, 2012 05:24 PM
wd 40 hurt the 0rings ?
posted September 21, 2012 06:00 PM
i use wd40 only. had my chain on since 07 (90% drag use) im finally due for a new one tho.
posted September 21, 2012 06:33 PM
Thanks Scott.. I just didn't want to screw up a 170.00 dollar Chain .. But if WD40 works it works ..
codyc_13
posted September 21, 2012 07:08 PM
ZZZ here, and I also only use wd40.
8.97 at 149mph
kllrvet
posted September 22, 2012 01:01 PM
WD40 HERE
ZX14 cam chain tensioner making noise? I have the set it and forget it fix. PM me if I can help.
Rajun Cajun
posted September 23, 2012 05:12 AM
I have used WD40 a few times on my last chain to clean it but didnt pay attention to speed/power gains. WD40 works very well to remove spray wax from your chain; wheels and fairings! It leaves a film that makes cleanup easy too.
Candy Thunder Blue 2006 ZX-14, +1 rear, RoaringToyz blocks, windscreen spikes! (VERY SHARP! DO NOT TOUCH!!!!)
Time lost can not be retrieved! Its not dumb to ask questions. Rajun Cajun
joseph702
posted September 23, 2012 03:35 PM
I use sewing machine oil . lol funny but works
FlatoutBu
posted September 23, 2012 04:05 PM
We have used this in our lockshop for almost 20 years. It works on everything and has teflon in it. I also use it on my guns...
http://www.treefortbikes.com/product/333222358379/152/TriFlow-Superior-Lubricant.html?gclid=CIjjpqX1zLICFehDMgodvk0AEg
06 Blue 14
9.008 at 153mph @ 195 suited
smokinstorm
Old Drag Racer
posted September 23, 2012 04:21 PM
Wow. I sell this where I work but we've always used Ballistol and PB Blaster instead of this product. Maybe I should take a can back to the shop and tell the guys to try it.
2005 Turbo Busa
2001 GSXR 1000
posted September 23, 2012 06:32 PM
I notice the same thing Lee...Bike reacts faster with a tight chain !!!
I use gear oil as chain lube...
posted September 23, 2012 07:44 PM
That sounds good to me .. I had Chris Jones tell me to run it tight also .. I watched him set RG chain with RG setting on the bike .. He had it pretty tight .. I was thinking the best lube to free up HP would be to some Syn Oil on a rag and lightly wipe down the chain with it .. I tried that with my DZR2 chain and it took longer for the chain to start kinking up while street riding ..Lasted much longer than chain lube did ..It does get a little nasty if you use too much ..
Bigbore4
posted September 24, 2012 02:01 AM
wd doesn't hurt anything. I think you could put it on toast and it wouldn't hurt ya
Bishopzx12
posted September 24, 2012 03:47 AM
I agree I use WD 40 on almost anything.... I hate to go old school but anyone ever try the 3 in 1 oil it worked miracles for the chain on my HUFFY back in the day,LOL
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2002 GSXR 1000 "I was Drunk"
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
posted September 24, 2012 09:31 AM
In an ET game, a tight chain makes sense. For mph, I stick by a looser chain.
0.26257705688477 seconds processing time
