BIKELAND > FORUMS > ZX-14.com > Thread: ZX 14R Head & Cam deg NEW TOPIC NEW POLL POST REPLY
FAST Z14
posted September 06, 2012 01:57 AM
How much HP should I get if I flow the head & deg the cams on the 14R,the bike has Brocks CT single full system 16" muffler,ECU flashed & Bazzaz system.
My bike made 181 HP stock on tuner's dyno,after mods 196 HP.
Any predictions ?
FOLY HUCK
posted September 06, 2012 05:38 AM
...... flowing the head ? you mean porting the head ? Deg the cams will get you nothing ..Unless the factory put the cams in wrong and that doesn't happen .. You could pick up 10 + hp by milling 20 off the head and setting the cams back to the stock numbers ..
biggmoinc
posted September 06, 2012 05:56 AM
You'll add that wit race fuel wont u lee! Lol
biggmo@aol.com
Bishopzx12
posted September 06, 2012 07:31 AM
Lee whay would porting the head and milling it 0.20 on a 2012 zx 14r result in as far as power gains
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2002 GSXR 1000 "I was Drunk"
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
1badzx12r
posted September 06, 2012 08:09 AM
http://www.factorypro.com/tech/tech_tuning_procedures/tuning_cam_timing_tuning_proc.html
There is no serious professional team that doesn't individually set EACH engine's cam timing for best power.
But, I'd take a guy who says "I don't know, I haven't tried that." over a guy who says "Just set it at blah de blah and that will(?) be perfect.".
posted September 06, 2012 09:55 AM        Edited By: smokinZX14 on 6 Sep 2012 18:14
He didn't say porting the head , he said flowing the head .. Flowing the head is nothing but puttin it on a flow bench and check the flow numbers .. Now if he finds a good head porter and mills it 20 he will get more than 10 HP IF it is done right .. Seeing that the gen 2 head is already ported ( some what ported ) I don't think you will pick up much extra HP from a port job ... I guess maybe if ported correctly with 20 milled off the head you might see 20 HP , maybe less .. maybe more ..
posted September 06, 2012 10:08 AM
Kawi set the cams at 105 105 , i'm sure they spent pleanty of time to find the best numbers for the bike just like a race team .. I have tried pleanty of numbers on the gen 1 zx14s and 105 105 is the best number for our stock cams ... Aftermarket cams may work better with a different numbers .. The cam grinders will tell you the best numbers when you buy the cams .. You can play with the numbers a bit to move the power up or down the RPM band .. But there is no Harry Potter wand to wave around and make power that is not there ..Most all cams have a number .. lets say you got a Cam ground on a 112 center line , cam Grinder will have you install that cam at 4 Deg advanced or 108 installed .. That number will be very very close to making the best overall HP and TQ .. You can put it at 104 and make a bit more low end but it will take away some top end ... Set it at 114 and lose some bottom end and pickup a little top end power .. Or use the numbers the Cam grinder gave you and have a good all around power band .. I have done this for years , tried many many numbers to find that last bit of HP .. 99 times out of a 100 the Cam grinders numbers are the best ..
BLK ICE
posted September 06, 2012 10:53 AM        Edited By: BLK ICE on 6 Sep 2012 18:56
1. with short stacks, 47mm tbs, and 800 more rpms; do you think 105-105 is still the best "stock cams" setting to use the extra rpm/power up top?
2. If I shaved my gen1 head .025 and made no other changes would I pick up 15hp just from that? also, would cam settings be effected, or would 105-105 still be the best ?
Viper
posted September 06, 2012 11:10 AM
Lee our cams are set at 109- 105.
14R cam specs
In...33.4mm valves
In ....366 lift...opens 34*...close 72*...= 286*...109 Lobe Center
Ex...28.3mm valves
Ex...366 lift...opens 66*...close 36*...= 282*....105 Lobe center
2012 ZX14R SE
1badzx12r
posted September 06, 2012 11:21 AM        Edited By: 1badzx12r on 6 Sep 2012 19:30
Kawi set the cams at 105 105 , i'm sure they spent pleanty of time to find the best numbers for the bike just like a race team ...
Kawasaki set those cams for fuel economy and warranty and emissions .. not for best over all hp .. but why don't you take a stock bike and run against those racing teams that they talking about.. and see where it places you so confident in stock settings .. i'm confident them factory pro guys know were to set cams i see their bikes at race season RACING..
I think i'll call KWS and tell them to use stock settings http://www.youtube.com/watch?v=f9dpY_OalZQ
posted September 06, 2012 01:56 PM
14R cam specs
In...33.4mm valves
Ex...28.3mm valves
Viper i know .. I was talking about the gen 1 Cams not the new motor ..
cliffrandall
posted September 06, 2012 02:05 PM        Edited By: cliffrandall on 6 Sep 2012 22:07
From messing around with the 1270 - Cam timing is an interesting art, change the timing, change the power curve. Depends where you want the juice.....IMO, on the street big mid range torque often trumps max rpm hp. However my suggestion would be to check your's first, often times we just pull the sprockets off (machine shop equipment) and press them back on to get the fit perfect (degreeing the cams) with the existing chain set-up.....Food for thought.
Cliff
posted September 06, 2012 02:06 PM        Edited By: smokinZX14 on 6 Sep 2012 22:48
We are talking stock cams in a stock ZX14 not some Race Team with built motors and after market cams that we can't even buy .. But that is a nice video and what you need to use if you cut your head to keep from smacking your pistons into the valves ..
Go ahead 1bad get a zx14 and move the cams around and see how much power you can make ..I can tell you right now you will not make any extra power worth all the time you spent doing it .. Want more power change the cams to bigger ones ..Oh wait if you move the cams the cam sensor well be off and it will not run ,,,, Right 1bad ?
posted September 06, 2012 02:39 PM        Edited By: smokinZX14 on 6 Sep 2012 22:42
Yes 105 105 on your gen 1 motor would be the best .. BUT keep this in mind , jesses motor made 13 hp with just milling the head 20 thou and we were able to use 105 105 and not have a piston to valve clearance problem ... But at 25 thou you better double Check the PVC.. With a 20 cut on Jesses motor we were very close to the min number for valve clearence that i felt safe with .. With 20 cut and the cams at 105 105 i think we ended up with 55 thou PVC clearence ... That"s pretty close in my book .. Watch the video that 1bad posted , you can see the part where and how he check the PVC ..
1badzx12r
posted September 06, 2012 03:36 PM        Edited By: 1badzx12r on 6 Sep 2012 23:40
you got that right .. do your research.. .. maybe you should call brock and ask him how he set his cam sensor pin in that 1650cc busa motor.. i'd bet it ain't in a stock postion using stock degree numbers..
but hey if you want to keep these zx14 guys going slow ..cool
FAST Z14
posted September 06, 2012 10:34 PM
Sorry Smokin I meant porting the head not flowing, thanks for the info.
FOLY HUCK
Y2KZX12R
CompetitionCNC.com
posted September 07, 2012 04:07 AM
210 hp is about all your gonna get with stock cams and pistons. But you will need our 47mm throttle bodies and our super sport head burning mr12 fuel and a good tune.
On pump fuel your looking at 202 hp.
The super-sport head is bowl blended, special valvejob, and angle milled to to bring the CR to 13.2 and you will need to degree the cams. Set the intake cam as low as possible until you have .050" piston to valve clearance usually about 109-110.
The exhaust p to v should be about .060" and about 108-110.
Its the best bang for the buck if you dont plan on ever going bigger with the engine or putting our ported head and cams on it. If you want future build ability then dont do the SS head, there's better options.
Y2KZX12R
CompetitionCNC.com
BLK ICE
posted September 07, 2012 08:29 AM
Thank you very much for your reply, it is very helpful.
Sincerely,
BLK ICE
posted September 07, 2012 08:46 AM
Sincerely,
biggmoinc
posted October 01, 2012 05:05 AM        Edited By: biggmoinc on 1 Oct 2012 13:12
To get the stock cams degreed for jims ss head I'm guessing adj cam sprockets are needed?
Also with issue of ptv tolerances, would it be safer to run a 10600 rather than 10800 pill n Auto shifter to prevent rev limiter accidents due to bending valve issues n the ss head?
I've seen a few dyno tunes run bikes up til it hits limiter,, wouldn't that be an issue while tuning that ss head? Just trying to find out what NOT to for or let others due, funds are limited so I'll only have one shot at this!
biggmo@aol.com
0.22054004669189 seconds processing time
