BIKELAND > FORUMS > ZX-14.com > Thread: What kind of miles are you getting on stock chain? NEW TOPIC NEW POLL POST REPLY
Some Guy
posted August 31, 2012 07:08 AM
Just changed the change on my '08 14. The bike has 44,750 miles and there was still plenty of room to adjust it. I've just been doing weekly trips from Spokane to Seattle, and daily trips from Seattle to Olympia, and I didn't want to take any chances. Man I remember back in the day with my 85 zx900a2 I'd be changing the chain in 10,000 miles!
The chain still looked like it could keep going, but it did have a few links not straightening up as they should. I changed both sprockets while I was at it.
This bike is simply perfect for just about any use!! Even after arriving from my 300+ mile trip from Olympia to Spokane I feel I can just keep going to the East Coast!!
'08 SE ZX-14
'14 1000r Ninja (wife's)
1985 900 Ninja
zixxer14
Damn that was Quick
posted August 31, 2012 07:23 AM
Impressive, I changed mine out around 28k.
Quarter Pounder
with Cheese
posted August 31, 2012 07:58 AM
Good job taking care of it to get that mileage. You won't see that very often as most don't care for the chain that well.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
Some Guy
posted August 31, 2012 09:02 AM
Thanks. I clean it regularly using Simple Green and then oil it immediately afterward. I'm always trying different chain lubes so I can't say which is best. I normally aim for the cleanest, as in, sticky. As often as I clean/oil it, I'm not too worried about insufficiant lube.
'08 SE ZX-14
1985 900 Ninja
posted August 31, 2012 11:19 AM
If you got 44,000 miles out of a chain, I'd say your doing something right!
Seno
BANNED FOR LIFE!
posted August 31, 2012 12:06 PM
Simple green easy to clean the chain with? I never tried that stuff
epd345
posted August 31, 2012 09:23 PM
44k Awesome mileageout of a chain. I tried simple green but still like WD40 better.
dcjens
Wet side of Washington
posted September 01, 2012 05:47 AM
I agree..sounds like your doing it right with that mileage! Your in my neck of the woods too. I travel to Olympia every day from Federal Way myself. Ive got 31K on my chain and clean and lube similar to your schedule.
Black 06
Joe Cool
posted September 01, 2012 12:27 PM
Haven't tried simple green for cleaning...I usually use kerosene about every 4-5 lubes...it cuts through everything quickly, followed up by 80/90 gear oil. I had almost 30k on the bike when I was rear-ended and I think I made 3-4 adjustments during that time. The gear oil makes a bit of a mess but if you stay on top of it, it's not too bad. Clean up between lubes was usually just wiping the chain down.
chrisdhall
posted September 02, 2012 09:42 AM
I managed 33k miles on the original chain. I used a Scottoiler from new and cleaned it with diesel fuel every month. I changed it because although there was no real signs of wear - no tight spots or stretching, at about 80mph it had developed a whining noise that was getting worse.
Chris
0.2599048614502 seconds processing time
