BIKELAND > FORUMS > ZX-14.com > Thread: Not Starting NEW TOPIC NEW POLL POST REPLY
chromedout12r
posted August 29, 2012 07:04 PM
Not Starting
My Buddy has a 2006 ZX14. He cannot get the bike to start. It sounds as if the Fuel Pump is not cycling through when you turn the key to start the bike. It is not the Power Commander as we disconnected it. Could this bike with 12k miles have a bad Fuel Pump. It acts as if it wants to start, but will not start now smoke is coming from the tail pipe.
Newf14
2007 ZX1400
posted August 30, 2012 07:52 AM        Edited By: Newf14 on 30 Aug 2012 15:53
Battery bad maybe??
Newf14
colt
if u aint first your last
posted August 30, 2012 08:18 AM
Check battery and fuses you should hear fuel pump when u turn they key if not could be fuse or bad wire happend too me outher day on my 08 turned out to be a wire lose from me puting in cammander or neons if u got fuel check spark
Hayabusa14
posted August 30, 2012 08:38 AM
The quickest way to find out if you have a fuel problem are a firing problem is to spary some starting fluid in it. And it start, you have a fuel problem--if it does not start chance are you have a firing problem. Just enough to start. Do not run it this way for long.
2012 SE-ZX14R [CT Meg-PC5 with street map-Evil swingarm 64" wheelbase-JRI shock], 2009 GSXR 1000, 2008 B-King, 2007 SE-ZX14 "Brocked out" - 1999 Hayabusa "stage 1" Turbo
chromedout12r
posted August 30, 2012 07:18 PM
He has been running it that way for a while. bike now refuses to start. Battery is fully charged and it is not the PC or Tip Sensor
cas15
posted August 30, 2012 07:57 PM
did u check the ecu
  Ignore this member    Click here to visit cas15's homepage.
0.20958518981934 seconds processing time
