epd345
posted July 30, 2012 04:59 PM
2012 Changing rear sprocket. Question
Is there anything I need to look out for with that rear sensor mounted on the rear disc when pulling the rear wheel off? I dont want to damage anything. Thanks for your assistance.
kaw-rick
posted July 30, 2012 05:10 PM
just take the bolt out of sensor and put sensor out of the way.
posted July 30, 2012 05:13 PM
Not really .. I pull the caliper off first and grab the sensor bracket as i pull the axle out just to make sure it doesn't hit anything ..If you are worried just remove the two bolts at hold the sensor and remove it first .. I don't think you can hurt it that easy ...
