BIKELAND > FORUMS > ZX-14.com > Thread: running on 3 cyl NEW TOPIC NEW POLL POST REPLY
joel787
posted July 28, 2012 12:27 PM
running on 3 cyl
I went to the track last night, everything was fine, then this morning I started the bike up and it sounds like its running on 3cyl plus is leaking fuel through the header and down pipe union...WTF anyone has have this happened before?
BrucerZX14
posted July 28, 2012 12:35 PM
Check the plug. Might have snuffed it out.
joel787
posted July 28, 2012 02:51 PM        Edited By: joel787 on 28 Jul 2012 22:54
Checked the boots, everything was tight...took the plugs out they looked fine...what else should i check? How can i test for spark its kinda tight in there...and the leaking fuel? If is not burning is it normal for it to spit it trough the header??
Oz Booster
posted July 28, 2012 02:54 PM
Don't trust the look of a plug, just replace it , or at least swap it and see if the problem moves to the other cyl
Wheelie
Old Man
I don't know if it will help but try reloading the map.
wee
joel787
posted July 28, 2012 03:05 PM
Yeah my next step is changing plugs[
quote] I don't know if it will help but try reloading the map.
wee
I did run a new map last night, it might be it? But how did it work fine a whole night then went to shit the next day...i will try that
Master
If it ain't fast it aint me
posted July 30, 2012 07:41 AM
Ok joel listen up bud place the plug up against the engine grounding it turn the engine over to see if the plug gives a spark. If it does not give you a spark pull the cap off one of the good plugs and place it on the same plug grounding it to the frame and check for spark.
If it does not spark with either plug cap then the plug is bad. If it spark with one plug cap and not the other then either the coil is bad or the cap is bad or the ecu signal is not getting to the coil. Yes if the fuel is not burnt it will leak as you see it doing.
Listen to the Master he'll get you going in the right direction.
1badzx12r
posted July 30, 2012 01:24 PM
what he said ..if your using a coil kill and use shell clamps .. look there..
joel787
posted July 30, 2012 03:35 PM
Thats how they looked, i guess i was wrong #3 looked kinda melted and #4 was bunrt, changed them and its all good now,
posted July 30, 2012 03:42 PM
Burnt ? Melted ? You spaying ? If so you are too damn lean if you are burning and melting shit ..
kawpower
Mr kawasaki 2 you!
posted July 30, 2012 03:44 PM
Melted and Burnt? u better find a dyno and check A/F ratio !
joel787
Stock motor, thats what i thought but my log showed 13.6 WOT...could it be broken?
kawpower
Mr kawasaki 2 you!
posted July 30, 2012 03:46 PM
Something isnt right.
If you are sparying you better see 11.8 to 12.1 A/F not 13.6
joel787
posted July 30, 2012 03:49 PM
Im not spraying..pump gas
posted July 30, 2012 03:56 PM        Edited By: smokinZX14 on 30 Jul 2012 23:57
13.6 on a Gen 1 is lean ...Gen 1s like 13.1 to 12.9 on the track with ram air .. You should be using stock plugs also ..
1badzx12r
posted July 30, 2012 04:13 PM
did you plug off your kleen air ..
joel787
posted July 30, 2012 04:14 PM
Yes
1badzx12r
posted July 30, 2012 04:15 PM        Edited By: 1badzx12r on 31 Jul 2012 00:16
Yes
then your lean ..always start pig rich and back into it ..
1badzx12r
posted July 30, 2012 04:17 PM
when you start it check you crank case vent for blow back ..
joel787
posted July 30, 2012 04:18 PM
How come?...thanks
1badzx12r
posted July 30, 2012 04:22 PM
How come?...thanks
if you melted any piston ..you can catch it early and keep from having too much damage.. my eyes are bad but it sure looks like some aluminum flake on those plugs ..
joel787
posted July 30, 2012 04:24 PM
Damn, I was afraid of that but when I started the bike it was fine...should I drain my oil to check?
joel787
posted July 30, 2012 04:26 PM
If the vent spits oil then the piston its bad ?
1badzx12r
posted July 30, 2012 06:47 PM
correct.. the more rpm you give it the more air it pumps up the vent ... thats bad .. those plugs ain't as bad as some i've seen ..where the whole grounding straps were melted off and the pistons were fine but pitted .. but the metal from the grounding strap got behind the exhaust valves and pounded the seats .. thus failing a leak down test .. whenever i find something like your issue i do a leakdown ..the sooner you catch the problem the cheaper the repair most of the time ..
0.26601910591125 seconds processing time
