BIKELAND > FORUMS > ZX-14.com > Thread: New chain required?? NEW TOPIC NEW POLL POST REPLY
Lsantana954
posted July 23, 2012 10:33 AM
well im coming up on 8k miles on my 14R and looks like ill be needing a new rear sprocket soon. When i purchased the bike back in jan I changed out the factory chain and rear sprocket to a Vortex aluminum sprocket and an EK ZZZ530 chain both of which were brand new. I've decided to go with a supersprox rear sprocket and was wondering if i should or need to change out the chain? From what they claim the ZZZ chain is bout one of the strongest longest lasting chains one can get and if i can get some more mileage out of it that would save me a couple of hundred dollars.
Oh and by the way i will be changing the front sprocket when ever i decide to change the rear.
'12 Gully Blue ZX14
-PCV/Guhl ECU/Blue CT Meg/<0 Alyson Oil/+8 Evil Arm/+1 Rear Sprocket
'07 Acura TL-S
'87 Buick Grand National
joel787
posted July 23, 2012 10:36 AM
Probably still good unless you can see the ruber coming out from the links
Wheelie
Old Man
posted July 23, 2012 12:06 PM
I would replace both sprockets and the chain.. Used chain will wear out new sprockets, Used sprockets will wear out a new chain.
wee
Seno
BANNED FOR LIFE!
posted July 24, 2012 04:57 AM
+1, when changing sprockets I always replace the chain also... unless it’s a new bike
epd345
posted July 24, 2012 12:57 PM
I messed around with three different rear sprockets and never changed the chain on my 07 and that had just under 15k on it when it was sold. It probably would be a good idea to change them but it probably is not absolutely necessary. I also noticed that the chain on the 2012 seems to be stronger as I have not had to adjust it yet with over 2k miles. My 07 had streched by then and had been adjusted to take the slack out.
Lsantana954
posted July 24, 2012 03:26 PM
ive been runnin the EK ZZZ chain ever since the bike was purchased in jan.
'12 Gully Blue ZX14
'07 Acura TL-S
1badzx12r
posted July 24, 2012 04:38 PM
you needs to learn how to maintain a chain if only after 8k miles you need replacement .. i know that sprocket has a steel ring teeth
Lsantana954
posted July 24, 2012 05:06 PM        Edited By: Lsantana954 on 25 Jul 2012 01:08
i lube my chain every three gas fill ups...and no the vortex sprocket thats on the bike now doesnt have any steel teeth the one im looking at getting does.
And i never said i NEED a replacement but im looking at changing it out prob around 10k.
'12 Gully Blue ZX14
'07 Acura TL-S
joseph702
posted July 24, 2012 05:07 PM
the vortex dont last that long if u ride hard. the chain might be good but would kill new sprocket.
1badzx12r
posted July 24, 2012 05:36 PM
how often you clean it ..
Lsantana954
posted July 25, 2012 12:08 AM
same time i lube. I clean it with the chain brush and spray some sea foam on the brush then wipe it with a rag sprayed with some sea foam
'12 Gully Blue ZX14
'07 Acura TL-S
posted July 25, 2012 02:16 AM
I am OCD about my chain. I had my sprockets and chain for a couple thousand dragstrip miles on my 06 zx14, then put same sprockets and chain on new 14 in 09. They are still on there. Both vortex alum sprockets. 4,500 miles on 14 now with mostly dragstrip miles. They don't look too worn, but I'm going to replace soon. I live and Chilean my chain every trip/ maybe every other trip to the track.
1badzx12r
posted July 25, 2012 04:36 AM
i use diesel to clean with then i hit it with chain wax .. i get around 30k miles out of a chain and sprocket combo ..even with an alumium rear.. rear tires live around 7k miles sometimes longer.. sometimes less
SteddyTeddy
posted July 25, 2012 04:51 AM
With only 8k miles on that ZZZ chain, I would just install a new rear sprocket since your going back to steel teeth. On steel sprockets you should get up to 20K street miles or more with that ZZZ.
Lsantana954
posted July 25, 2012 08:45 AM
That was my thought teddy
'12 Gully Blue ZX14
'07 Acura TL-S
Wheelie
Old Man
posted July 25, 2012 12:50 PM        Edited By: Wheelie on 25 Jul 2012 20:51
Why would you install new sprockets on a used chain, then run the used chain less than 2k miles and buy a new one and install it on used sprockets?
wee
Lsantana954
posted July 25, 2012 01:45 PM
wee
in that statement i was refering to just changing out the sprockets...the question at hand is with this ZZZ chain would it be recommended to also change out the chain even though the rear sprocket is aluminum and ill be switching over to a steal rear sprocket.
'12 Gully Blue ZX14
'07 Acura TL-S
Wheelie
Old Man
posted July 25, 2012 01:49 PM
wee
sounds like you had you mind made up on using the used chain with the new sprockets, If it was mine it would have new everything at one time.
wee
Lsantana954
posted July 25, 2012 03:11 PM
no not really. I figured since this is one of the strongest longer lasting chains out in the market right now that one might be able to get away with swaping out sprockets with out the chain. I was just curious if anyone out there has had any personal experience with this chain
'12 Gully Blue ZX14
'07 Acura TL-S
blue07
posted July 25, 2012 03:33 PM
Yeah...you can....go for it.
Beondwacko
posted July 25, 2012 04:56 PM
9k miles on my chain running, currently a 16/40 , rear sprocket is aluminum and I still have room left for adjustments. Been running the aluminum rear for over 3k miles and its in very good condition. That's with I'd say better than 150 drag strip passes. Insert joke here. Maybe not really quick passes but still they count for something.
0.23963093757629 seconds processing time
