BIKELAND > FORUMS > ZX-14.com > Thread: GPR steering damper & lowering strap NEW TOPIC NEW POLL POST REPLY
lazarosp
posted July 15, 2012 01:26 AM
Hello everybody,
I have bought a few days ago a GPR V4 steering damper for my ZX14 and I also bought a lowring strap kit. They did not delivered to me yet, after buying them I started to think about mounting, I forgot about it. Does anyone have a solution? Any pics?
Rich
Just havin' fun!!
posted July 15, 2012 02:32 AM
I have a GPR on mine, so I run my strap over the gauge bracket. I tighten it down at the track and it stays loose the rest of the time just riding on the street. I've had it like this for about a year and a half now.
07 Green and Black, How fast is fast?
203 for now. Limited $$ = limited HP.
  Ignore this member    Click here to visit Rich's homepage.
lazarosp
posted July 15, 2012 03:41 AM
Can you post a pic?
1badzx12r
posted July 15, 2012 04:22 AM        Edited By: 1badzx12r on 15 Jul 2012 12:25
i see its work for you..but thats a bad idea.. if you ever break 1 those bolt lugs its a no fix.. i had purchased a frame with a broken top lug once.. we welded and everything but it would break after time again
Rich
Just havin' fun!!
posted July 15, 2012 04:34 AM
OK 1bad. I can't be the only guy using a strap and a GPR. Does anyone have a better way with this combination? I know the strap normally goes right where the GPR bolts on.
I ride pretty much every day and don't have any problems on the street. I haven't had any problems at the drag strip or LSR, but if there's a better way, I'm up for it.
In the photo, the zip tie is on my charger, not the strap. The strap is kinda hard to see, but it's basically underneath the ignition. The slack comes off to the left and is looped up neatly underneath my clutch reservoir with a zip tie.
Rich
Just havin' fun!!
posted July 15, 2012 04:37 AM        Edited By: Rich on 15 Jul 2012 12:38
OK 1bad, now that I posted I can see your explanation. I hadn't of thought that breaking out.
Thanks.
posted July 15, 2012 01:09 PM
I put the strap on and then mount the damper, it will fit.
mick46
posted July 15, 2012 01:42 PM
+1 Shane... Its a tight fit but does !
2012 ZZR-1400
Alien Frogskin Green
Brocks CT Meg, PCV & QuickShifter, Brembo M4 Monoblocs, Grimeca 320mm discs, Nitron Race shock, Gilles rearsets , adjusters and TCA axle nut, Supersprox 42T, DID nickel plate X-ring, HEL brake lines, bar risers, shorty levers, tail tidy, Zero Gravity screen, RandG spools and bar ends, GPR V4 damper.... Done !
1999 Hayabusa , stretched lowered and a 60 shot !
Rich
Just havin' fun!!
posted July 15, 2012 05:01 PM
Thanks Shane and Mick46.
0.22279500961304 seconds processing time
