BIKELAND > FORUMS > ZX-14.com > Thread: Brocks system, what's the red cap for? NEW TOPIC NEW POLL POST REPLY
epd345
posted July 11, 2012 05:42 PM
Starting to mount the pcV and Brock's CT meg tonight. i have a small red cap at came with the system. I know it's to block off some hose. Can someone tell me which hose I'm blocking off with the cap and what it does. Thanks
Kawifast
posted July 11, 2012 05:57 PM
It's a pair cap. The cap is to block off emissions and assist in eliminating decel pop. It also helps keep ram air levels from the airbox. If you have a 14R go to Brocks site and download instructions. You'll need to remove the "left" fairing for the 2012 vs the right on prior years. His instructions are very clear and easy to follow
2012 Kawasaki ZX14-R
2012 BMW S1000RR
2012 BMW K1600GT
epd345
posted July 11, 2012 06:13 PM
Ok thanks. It's a 2012. I will see if I can find instructions. I have all the fairings off now and have pc and pipe installed.
Kawifast
posted July 11, 2012 06:27 PM
Cool you're very close Just go to Brocks site and click on install instructions for the 2012 Pair cap. Not a big job. Let us know how you like the pipe once you get it buttoned back up.
2012 BMW S1000RR
2012 BMW K1600GT
Lucky14
posted July 11, 2012 06:28 PM
http://www.brocksperformance.com/Instructions/ZX14/996395.pdf
epd345
posted July 11, 2012 06:54 PM
I did fire it up after I got the pipe and Pc-v in. It sounds bad ass. Very mean, thanks for the assist on the cap
BIKELAND > FORUMS > ZX-14.com > Thread: Brocks system, what\'s the red cap for? NEW TOPIC NEW POLL POST REPLY
0.36209201812744 seconds processing time
