BIKELAND > FORUMS > ZX-14.com > Thread: Timing retard for using NOS NEW TOPIC NEW POLL POST REPLY
edszx14
posted July 09, 2012 09:09 AM
Who has a good system for retarding the timing when using NOS and about how much timing should be retarded for anything above a 40 shot. Thanks for your help.
Ed
dakota9498
posted July 09, 2012 09:38 AM
I think the easiest setup would be an MSD SB6. I have a few friends using it with a lot of success and that will be the route that I go in the near future.
2008 ZX14
edszx14
posted July 09, 2012 10:53 AM
Thanks Dakota, I appreciate the advice.
Ed
06redzx14
posted July 09, 2012 11:16 AM
easiest, but hardest to find is schnitz efir.
quikgix
posted July 09, 2012 09:20 PM
SB6 is what I use,hook the brown wire to the activation side of a nitrous controller and set it to retard down to 10 degrees on the hit and ramp it up where you want for a set amount of time. works killer.
1352cc 8.39@159mph on motor cant wait to spray this bitch
BLK ICE
posted July 10, 2012 07:26 PM
zx14 EFIR if you have 06-07 works great if you can find 1. how much timing you pull depends on your fuel, c/p ratio, and a lot of other factors, it is best to have it set-up by a pro. the first time for anything over a 40shot.
edszx14
posted July 11, 2012 08:53 AM
Hello guys, Thanks for the input and advice. My bike is an 08 so would the EFIR work on it,
Ed
CJ
posted July 11, 2012 09:17 AM
Sb6 x10
07 plasma blue zx14
Ain't no fun when the rabbits got the gun
BLK ICE
posted July 11, 2012 10:12 AM
No, only 06-07
edszx14
posted July 12, 2012 07:08 AM
Thanks BLK ICE. Much appreciated.
Ed
RICH CRAFT 1
posted July 12, 2012 07:42 AM
the SB 6 for timing retard, and a lot of the stuff. $550 the wego three for air fuel, it also has a data logger to show wheelspin, and a lot of other stuff. $400
a new motor $2000 plus labor, for not being able to monitor the stuff.
nitrous has torn up a lot of motors, but not for those people who follow the rules.
Ken
Red 06 ZX14 RR
edszx14
posted July 12, 2012 06:20 PM
Hello Ken, will the Wego III retard the timing, also. I do like the fact that is logs the AFR, wheel spin but if it will do the timing, I am sold. Thanks for the info.
Ed
BLK ICE
posted July 12, 2012 10:01 PM
No
Seno
BANNED FOR LIFE!
posted July 13, 2012 05:05 AM
Ken
So spend a little now, or double that later... Makes sense. Is it necessary to retard if only running a 30-40 shot?
Rich
Just havin' fun!!
posted July 13, 2012 02:41 PM
Seno, I've been waiting a bit for someone more experienced on spray to answer, but I'll give what I've found so far. I've run up to a 40 shot at the drag strip and at the Ohio Mile. I've run this on E85 both places and on 93 octane just at the drag strip. I don't pull timing. This was on good advice from others who have WAY more experience at this stuff than I do. I've been told a 40 shot is good for years, as long as your AFR stays good.
07 Green and Black, How fast is fast?
203 for now. Limited $$ = limited HP.
  Ignore this member    Click here to visit Rich's homepage.
RICH CRAFT 1
posted July 14, 2012 06:16 AM
ed, no the wego three will not retard timing. That's why you have to have both of them . Wego three and SB six. The SB six does a lot of stuff. It will retard and advance your timing, any way you want it to happen! I think 5° advance 15° retard. It also has a built-in to step that's adjustable any way you want that to happen. The wego three has a data logger that allows you to see the run afterwards showing you wheelspin, RPMs, and air fuel. There is no need for a tuner. When you have these tools at your hand, if you know what you're looking for.
Basic rules for nitrous, retired 2° for every 50 hp, since the 14 likes about 2° advance . Most people can get away with a 50 shot with no timing taken out. But around 50 hp is where the valve springs start giving up. It's borderline at the track. If you cooled engine down every time, but not on the street. I have no experience with the 14R as far as valve Springs.
To be on the safe side. I would take 6° out for 100 shot, use C12 fuel, C 16 is safer butt hurts power, air fuel should be around 11.9 to 12.1 It's not recommended to use oxygenated fuel and and nitrous.
Ken
Red 06 ZX14 RR
edszx14
posted July 14, 2012 07:23 PM
Hello Ken, Thanks so much for the advice. Sounds like the Wego IIi and the SB6 may be on my Christmas list. Right now i am using Q16 fuel and I am assuming Q16 hurts power like C16 does. Would you know how much power is lost? My bike dynos at 181 horses.
Thanks,
Ed
Audio
posted July 17, 2012 07:24 PM        Edited By: Audio on 18 Jul 2012 03:28
I run a SB6 and take out 3 deg for a 56 shot on my 08
I know q16 loses power off the gas, i would guess and say 4 or 5 % but its alot safer on the gas. It think on the gas it make it up then some.
Audio
2008 ZX14 Old Gray CNC-1414 old new CNC ?
2012 ZX14R SE Green CNC-?
edszx14
posted July 18, 2012 06:12 AM
Thanks Audio. I guess I need to get me a SB6. Probably be this winter. Thanks again everyone for the info and advice.
Ed
debo33
posted June 20, 2013 06:35 PM
Just saw were someone said ur bike lose power on q16. How is that??
Lonnie Anthony
  Ignore this member    Click here to visit debo33's homepage.
0.25889706611633 seconds processing time
