BIKELAND > FORUMS > ZX-14.com > Thread: PCV Device Code Error NEW TOPIC NEW POLL POST REPLY
Romans
posted July 06, 2012 06:18 PM
Any body have this before ???? Code 77 Invalid max enleanment ???? If so how do i clear ?
1badzx12r
posted July 06, 2012 07:32 PM
new 1 on me
boostphreak
posted July 06, 2012 08:47 PM
call dynojet during regular hours and have your pcv hooked to your computer. They will walk you thru it. they will take over your computer and check everything out, clearing any codes, etc..took em about 10 min to do mine. better than sending it to em and having to wait...
zx12mark
posted July 06, 2012 09:28 PM
yeah it`s cool to watch your mouse arrow move and click by itself....it`s like somebody else tying your shoes.....creepy
Romans
posted July 07, 2012 09:48 AM
new 1 on me
Ya, me to. Auto tune will no longer will give trims #. Was just checking to make sure there was not a simple reset.
Romans
posted July 07, 2012 10:32 AM
hmm,,, google,,,, just found. I will try when I get home from work.
Answer: The Power Commander is able to display trouble-codes through showing different device errors. To "Reset" the Power Commander, go to the "Tools" menu and select "Environment Options." In the Environment Options screen, hold the control key (Ctrl) down on the keyboard and hit "R". This will bring up a "Reset Power Commander" button. Select this option and let the software reset the unit. After the unit is reset the error should go away. In most cases the Power Commander can be reset and the error will go away, but if that is not the case, than the unit may need to be sent in for testing. Contact Dynojet for technical support regarding a recurring "Device Error".
Bad in Black
posted July 08, 2012 12:27 AM
Good to know Rick
Romans
posted July 08, 2012 03:42 AM
Good to know Rick
I thought so too,,,, but,, didn't work. Nothing happens when I tried the above. No Reset pops up Nothing, Zip ?????
Will try tech support on Monday. Must leave work early to do it though,,,, grrrrr. Not Good.
Reset info should be available to ALL. Was hoping If reset does not clear the fault then call Help Line.
Waiting for a work day does not help us on the week end.
DynojetResearch
posted July 11, 2012 02:35 PM
The above information is for PCIII models, not the PCV. Code 77 is for the Auto tune setup. The default for max enleanment is -20. If you have a value lower than -50 is will give you an error. Check these setttings.
Dynojet Tech team
Romans
posted July 11, 2012 02:41 PM
Thank You,,,, Jay got me fixed up. Problem was I had a minus sign in front of my number.
I was pulling fuel from cells and then went into config and then entered a negative sign in front of the number 3. My Fault totally. Shhhh, going to my room now lol.
0.25434994697571 seconds processing time
