BIKELAND > FORUMS > ZX-14.com > Thread: nitrous gearing??? NEW TOPIC NEW POLL POST REPLY
CJ
posted June 20, 2012 05:38 PM
nitrous gearing???
I'm running out of gear about the 1000' mark hit the rev limiter through the traps.
weight is 165 suited 100 shot of NOS 16 front 41 rear sprockets. Does anyone have a good sprocket combination recommendation thanks for any suggestions.
07 plasma blue zx14
Ain't no fun when the rabbits got the gun
posted June 20, 2012 06:02 PM
17/41
Lucky14
posted June 20, 2012 06:08 PM
Gearchart says 196 mph @ 11k in 6th, 176 mph in 5th.
What gear are you in at the traps???
What mph are you running?
06redzx14
posted June 20, 2012 06:49 PM
Put the stock front back on
smokinstorm
Old Drag Racer
posted June 20, 2012 11:00 PM
X2. Holy Crap. How fast ARE you running????? I know stock rev limiter is at an actual 10,600 but still. How fast are you trapping? Something seems amiss here.
2009 Monster Edition ZX14
It's all stock I swear. Well...almost.
2005 Turbo Busa
2001 GSXR 1000
Looking for a 1985 GS1150E
CJ
posted June 21, 2012 01:51 AM
6th gear @ 170mph hitting the rev limiter. Going to put 17t back on the front and see what happens but I don't think I will see a 196 mph though we will see Friday.
07 plasma blue zx14
Lucky14
posted June 21, 2012 04:06 AM
Actual rev limiter is about 11,030 or some silly number like that.
Tach will be reading high at about 11,300
It is possible to run a 10.8 or 10.9 chip in the autoshifter without hitting the limiter.
LeonidasZX14
posted June 21, 2012 04:25 AM
Better figure it out quick, because I would hate to bust your ass when I get a 2012.
09' ZX14
LeonidasZX14
posted June 21, 2012 04:29 AM
Take that gearing commander garbage and throw it away. I 've ran out of gear with with 17/41 with the turbo set up and that's a fact.
09' ZX14
Lucky14
posted June 21, 2012 04:48 AM
Weren't you running in the 190's?
bigwil
06 zx 14 turbo stage 3
posted June 21, 2012 04:55 AM
Hey leonidas what gearing did you end up going on the turbo
bigwil// going fast aint easy so turbo it
CJ
posted June 21, 2012 05:25 AM        Edited By: CJ on 21 Jun 2012 13:48
Only thing between u and I is air and opportunity but wait a minute............ My 07' just sucked up all of that air with a whole bunch of nitrous ain't nothin' to it but to do it. I know u r gonna come out of that corner swinging november and Georgia ain't that far away.
AINT NO FUN WHEN THE RABBITS GOT THE GUN HOMMIE
07 plasma blue zx14
LeonidasZX14
posted June 21, 2012 06:58 AM        Edited By: LeonidasZX14 on 21 Jun 2012 14:59
very true!
09' ZX14
LeonidasZX14
posted June 21, 2012 07:05 AM
Best with 17/41 i was stuck in the 180-185 range. I went 190s with 17/39 in 6th gear which is what I ended up sticking with.
09' ZX14
LeonidasZX14
posted June 21, 2012 07:06 AM
17/39 but I weighed about 145 suited.
09' ZX14
quikgix
posted June 21, 2012 09:11 AM
16-41 and I hit the speed limiter on mine also at 170 at the stripe with a 60 shot. I just had my ecu reflashed and added 1000 rpm. Im gonna attempt "piston swapping holes" rpm's. Lol
1352cc 8.39@159mph on motor cant wait to spray this bitch
CJ
posted June 21, 2012 10:31 AM
Quikgix who reflashed your ecu??
07 plasma blue zx14
Beondwacko
posted June 21, 2012 11:21 AM
Now I wonder about my sanity. A couple of years ago, some guys I know we're doing top end runs with a gps, .9 mile stretch of road. I hit 169.2 on the gps with 16/41 gearing. I thought maybe I never made it to 6th gear.
Wheelie
Old Man
posted June 21, 2012 12:03 PM
is that 16-41?
wee
JZX
posted June 21, 2012 01:15 PM
Gearing commander is in correct. If you are running a shinko, which is alot shorter, then aired down at 18-20 psi shrinks the hight even more. I run 17-47 and It rev limited 5th(auto shifter chip pulled) at 155mph before the traps in 5th gear and I had 28 psi at the time. Not sure if that's anywhere close to gearing commanders specs..
06 ZX14 65"
Best 1/8 mile 5.68@126.4 on a 1.41 60'
Best 1/4 mile 8.87@152.7 on a 1.47 60'
quick6
posted June 21, 2012 02:30 PM
we run 16-43 on the grudge bike with no problems. you guys sure youre not running thru the clutches. heck the owner even ran 16-45 at the rock a couple weeks ago.
2006 zx14, fully dressed and sliding(Charlie Sheen)
Lucky14
posted June 21, 2012 03:20 PM
is that 16-41?
wee
Yes.
That is using Brock's Gearchart for a quick calculation.
I'm not saying the numbers are absolute as it does not take into account a shorter tire. However, at speeds near 200 mph, I would think there would even be some tire GROWTH.
The numbers are not absolute, but they are not off by 26 mph.
Tire spin and / or clutch slippage are likely to be causing the large inconsistancy between calculated and actual speeds.
Remember that the stock gearing of 41/17 on the 14 is good for over 200 mph (theoretical) and we are only talking a difference of 1 tooth.
Lucky14
posted June 21, 2012 03:29 PM
I run 17-47 and It rev limited 5th(auto shifter chip pulled) at 155mph before the traps in 5th gear and I had 28 psi at the time. ..
Calculating only on the difference in 5th gear and 6th gear ratios (tire size is whatever it is to run 155 mph in 5th), you would be good for about 172 mph in 6th.
That would be almost the same gearing as 16-44.
06redzx14
posted June 21, 2012 04:42 PM
Quick are you spraying off the line?
Red1
posted June 21, 2012 06:39 PM
I would try 17/40 or 17/39
Red12/Blue14
0.26958894729614 seconds processing time
