BIKELAND > FORUMS > ZX-14.com > Thread: Testing Drag Pack clutches and a New record for me 8.47 ....... NEW TOPIC NEW POLL POST REPLY
posted June 14, 2012 08:15 PM        Edited By: smokinZX14 on 15 Jun 2012 04:39
Density Altitude: 2187 feet
Relative Density: 93.76 %
It was 91 deg when i showed up at the track , humidity around 70 % .. I'm thinking to myself this is going to be fun just to get the bike to run anywhere in the 8.50s .. Well i'm testing the new clutches and not all that worried about the numbers anyway ..
The new clutches were a bit grabby for the first two runs and then seemed to seat in and start working like my factory clutches did .. First two runs the bike spun out of the hole because they were releasing a bit faster than the track could hold .. Third run i was able to slide the clutch out just like the OEM clutches .. I was still having a bit of wheel spin so for run number four i backed off my RPMs to 5k from 5500 and rode the clutch out just a bit longer and the bike hooked good ... First three passes where low 8.50s @ 160 with 60 footer in the low 1.40s .. Hummmmmm low 8.50s with 1.40 60 foot times in the heat on a greasy track .. Man if i could just get this bike to go a low 1.30 60 footer i'd be in the high 8.40s .. I dropped the air PSI in the tire down to 15 from 20 PSI , i knew that would kill some MPH but i was looking for ET and not MPH ...Next pass i hit it harder out of the hole and hit a 1.33 60 footer .. The pass felt real clean and the ticket backed up what i felt ..
At this point i forgot all about the clutches because they seems to be working so well .. The Drag Packs do work like many here on Bikeland have said they would , i have no clue at this point if they will out last the OEM clutches.. I'll keep count of the passes i make on them and see if they out last the OEMs ..
I was worn out from the heat and the track just got oiled down by a car after my last pass so i loaded up and came home ..I just didn't want to wait an hour for them to clean the hole left lane .. But i did drive home with a smile on my face ..
Viper
posted June 14, 2012 08:22 PM
Good job
2012 ZX14R SE
dakota9498
posted June 14, 2012 08:41 PM
Great job smokin! I can't wait to see this thing in good air this fall.
2008 ZX14
posted June 14, 2012 08:42 PM
Me too !!
CraZX14
posted June 14, 2012 09:47 PM
You are smokin', Smokin'! Great job, man
2003 L.E. Hayabusa
madnessracing
Vmax and Busa Beater
posted June 14, 2012 10:18 PM
You're flying Lee
Shorty's Performance
Team Madness Racing
01smokes
posted June 14, 2012 11:24 PM
You sure are getting it done!!! I want to see you spray this thing one day!!
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
Superman T
posted June 15, 2012 01:39 AM
Awesome job Smokin!
Seno
BANNED FOR LIFE!
posted June 15, 2012 02:03 AM
Sweet man, good work. The Dragpack works very well, they are made by KG.... Had one in my 07.
kawasakijockey
posted June 15, 2012 02:47 AM        Edited By: kawasakijockey on 15 Jun 2012 10:47
Dwayne at CC says they are not made by KG. I had gotten the same info from Greg on that other site but Dwayne came here and straightened me out.
BTW, that's a great run this time of year Lee.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
Rich
Just havin' fun!!
posted June 15, 2012 03:08 AM
Nice work Lee. That number just keeps going down and down and down
I wonder what you could do with that one on spray?
07 Green and Black, How fast is fast?
203 for now. Limited $$ = limited HP.
  Ignore this member    Click here to visit Rich's homepage.
edszx14
posted June 15, 2012 03:40 AM
Nice job, Lee. I have a set ready to go in my bike as soon as the ones in there give up the ghost. Again, nice job.
Ed
02zx12rbob
posted June 15, 2012 03:49 AM
Damm good Job !!
posted June 15, 2012 04:07 AM
Good job! I'm using his second clutch in 3 years.
Hayabusa14
posted June 15, 2012 04:12 AM
Great run Lee, keep up the good work. I have the same clutches in my ZX14R.
2012 SE-ZX14R [CT Meg-PC5 with street map-Evil swingarm 64" wheelbase-JRI shock], 2009 GSXR 1000, 2008 B-King, 2007 SE-ZX14 "Brocked out" - 1999 Hayabusa "stage 1" Turbo
Bently
2012 14r In Blue and no Mods!
posted June 15, 2012 04:21 AM
Wow! great numbers.
CajunBoyz
posted June 15, 2012 04:25 AM
Gret work Lee, Do u now have the drag shock from Brocks & the Drag pak??? Man In good air you might hit a .399 ???? Time will tell
Bently
posted June 15, 2012 04:33 AM
He's had a 1.30 60 footer before which would have made that run atleast a 8.42 so a pass in the 8.30's is there IMO for sure in good air. then there's always MR12!
cas15
posted June 15, 2012 04:43 AM
Nice
  Ignore this member    Click here to visit cas15's homepage.
SteddyTeddy
posted June 15, 2012 04:46 AM
Good job Lee!
Busabeater2
posted June 15, 2012 05:57 AM
Awesome job
1badzx12r
posted June 15, 2012 06:22 AM
congrats almost there ..
Famous1
posted June 15, 2012 06:49 AM
Wait..... What?..... Gtfoh..
dakota9498
posted June 15, 2012 07:31 AM
I would settle for it weighing what mine weighs, forget the spray. If his bike weighed 460lbs imagine what it would be running.
2008 ZX14
1badzx12r
posted June 15, 2012 07:56 AM
around the same as any 1441 grudge busa...
0.25794005393982 seconds processing time
