BIKELAND > FORUMS > ZX-14.com > Thread: need help with wiring radar detector NEW TOPIC NEW POLL POST REPLY
esram
posted May 22, 2012 01:51 PM
Need help wiring radar detector, 14r
Thanks in advance
Ninjawarrior1244
posted May 22, 2012 02:05 PM
Red wire to fused hot side, black wire to ground......
Turn it off when you dismount, and turn it on when you start the engine.
Speed is fine...but accuracy is Deadly!
Wheelie
Old Man
posted May 22, 2012 02:12 PM
Thanks in advance
use a positive wire that is hot when the key is turned on, you wont have to worry about leaving the radar detector on when you park.
wee
dakota9498
posted May 22, 2012 03:59 PM
Thanks in advance
wee
But that's not what GoldNinjaWarriorWingMan said?!
2008 ZX14
Wheelie
Old Man
posted May 22, 2012 04:18 PM
Thanks in advance
wee
lol
wee
mick46
posted May 23, 2012 10:34 AM
The feed to the brake light switch (front master cylinder) is both hot with the ignition and also very easily accessible !
2012 ZZR-1400
Alien Frogskin Green
Brocks CT Meg, PCV & QuickShifter, Brembo M4 Monoblocs, Grimeca 320mm discs, Nitron Race shock, Gilles rearsets , adjusters and TCA axle nut, Supersprox 42T, DID nickel plate X-ring, HEL brake lines, bar risers, shorty levers, tail tidy, Zero Gravity screen, RandG spools and bar ends, GPR V4 damper.... Done !
1999 Hayabusa , stretched lowered and a 60 shot !
ShayneThill
posted September 09, 2013 12:46 AM
No more radar detector. Radar detector and cheap metal detectors are not allowed to use in my stares.
cliffrandall
posted September 09, 2013 01:02 PM        Edited By: cliffrandall on 9 Sep 2013 21:04
Agreed, use the rear brake light as an auto-ignition based on & off. Great to get the Beltronics (upfront) remote light kit for their ST1 undetectable, then hide the main unit in the bodwork.
Cliff
Seno
BANNED FOR LIFE!
posted September 09, 2013 01:30 PM
Cliff, that last picture looks like you stuffed 10 pounds of shit into a 5 pound bag... But I guess that's for the guy who has to have everything....
cliffrandall
posted September 09, 2013 01:53 PM        Edited By: cliffrandall on 9 Sep 2013 21:57
With juice, you need to know what's going on. The EGT's are instant, the A/F read-out is good confirmation, albeit after the fact.
Cliff
0.22668600082397 seconds processing time
