BIKELAND > FORUMS > ZX-14.com > Thread: autotune or not W/ PC V NEW TOPIC NEW POLL POST REPLY
bizzsteve
black ZX14R 2012
posted May 03, 2012 06:39 AM
2012 full yoshimura PC V I spoke w/ a dynojet rep about a map for my set up he sugested
I buy an autotune. When I spoke to the rep at more power racing he said use the avalable maps until mine comes out autotune works but is far from necessary.
  Ignore this member    Click here to visit bizzsteve's homepage.
1badzx12r
posted May 03, 2012 06:42 AM
i don't like the auto tune .. it never stops adding numbers .. and i mean big numbers .. you keep accepting the trim numbers ...before long you get a map that won't even run ..
IDK maybe i got a defective one
bizzsteve
black ZX14R 2012
posted May 03, 2012 06:50 AM
It sounded like a sales pitch by the dynojet rep, made me feel like I was talking to a con man.
1badzx12r
posted May 03, 2012 07:14 AM
Don't get me wrong ..it helps but it never stops helping ..you would think it would stop with the big adjustments somewheres.. sometime i'll catch it adding 20 in 1 box and then it -20 the next time and -15 then next time and back to 20 then next time .. its like it confused or i'm confused... like WTF
wrongway
posted May 03, 2012 10:28 AM
you were confused
Roy
1badzx12r
posted May 03, 2012 11:01 AM
you were confused
Roy
IT MADE ME THAT WAY ...
Meangreen14
posted May 03, 2012 12:34 PM
Mine does the same thing, think depending on weather and temp. It will always alter the map..
PCV, quick shifter, stock gearing,
fly's out, custom garrett gt28 stage1 turbo, JE pistons, 625cc inj, MTC lock up clutch,1:1 fuel pressure regulator...
Meangreen14
posted May 03, 2012 12:43 PM
Under 100# throttle at high rpm's it doesent change map very much, you can also add or subtract the % amount autotune is tring to modify.
1badzx12r
posted May 03, 2012 01:00 PM        Edited By: 1badzx12r on 3 May 2012 21:04
yes i understand that .. i put the big values to see how much it would change from 1 ride to another on same day riding ..
there was days i never went into 80% to 100% throttle and it showed adjustments needed in those values..
i do test these product just for the hell of it and see how well they work for my own benefits ..
i like the bazzaz much better ..
Meangreen14
posted May 03, 2012 01:15 PM
That's wierd on mine if I don't rev it past 6000RPM it won't show any adjutments on table. Maybe just varies from autotune to autotune
1badzx12r
posted May 03, 2012 01:32 PM
i've let dynojet support twice into my laptop to fix an issue i was having with the software .. it would pull a map from nowhere up and if you didn't use the GET MAP TAB 1st ..to set your map onto the view tables .. you would send some fuck up map out of nowheres into MY PCV... it was funny watching them try to download that easy firmware upgrade and it bust their ass for a change..
0.25289106369019 seconds processing time
