BIKELAND > FORUMS > ZX-14.com > Thread: Anyone familuar using Map switch on a PC-V? NEW TOPIC NEW POLL POST REPLY
CajunBoyz
posted April 11, 2012 05:38 AM
Yes was helping a friend,
i'm helping a Close friend on his zx-14R. We purchased all parts from Brocks.My questions are on using the Map 1 & Map 2 switch. I will state that the map switch IS working(checked it with a ohm meter), & wired correctly per schmatic .. when switch is open, that is Map 1, closed switch is Map 2. We have the PC-V, But I'm having trouble knowing if the Map switch (map1 & map 2) is working?? I can send Your street map to map 1, & then send my Trial map to Map 2. On the computer when I click on fuel Map postion 1, it shows your street map, When i click on fuel Map postion 2, it shows My Trial map.. But is there a way to tell on the computer which map your on>? because nothing happens when you switch to map 2.. It seems like something isn't right???
almost_les
posted April 11, 2012 10:35 AM
plug it into the computer, power it up. right click on the "guage panel" in the power commander v control center (green numbers on the right side) add a gauge to display current map
CajunBoyz
posted April 11, 2012 05:03 PM
Ok, Sooo once i add a gauge to display "current Map" I will then see map 1 or map 2 when i toggle the map switch???
CajunBoyz
posted April 11, 2012 10:51 PM
bump
almost_les
posted April 12, 2012 09:12 AM
that's how it should work
CajunBoyz
posted April 12, 2012 12:46 PM
Ok, Your help worked, I'm 99.9 complete. The only thing i now can't explain, is open swith is current Map 1 Closed switch is current Map 2.. Mine is back wards, closed swith reads current Map 1 & open switch reads Current Map 2(backwards)??? Tech & Jamie said what ever it says in the software is the Map its on??? Just don't see why its back wards.. By anyway Thanks for the help & if you know anything about what i just mentioned,Kick it back. Again THANKS
almost_les
posted April 12, 2012 11:00 PM
you may have you switch wired incorrectly. what map does it say if you pull the wires from the switch out of the power commander? this would be the same as having the switch in the open position (no continuity). if is still says map 2 then i guess the power commander does have it backwards.
CajunBoyz
posted April 13, 2012 12:30 AM
Yeah, I got it all complete now, & just wanted to say thanks again for the help.
0.27419304847717 seconds processing time
