BIKELAND > FORUMS > ZX-14.com > Thread: ZX14R Unleashed NEW TOPIC NEW POLL POST REPLY
Seno
BANNED FOR LIFE!
posted April 11, 2012 03:20 AM        Edited By: Seno on 11 Apr 2012 11:49
ZX14R Unleashed
Finally got this project over with and I am happy with the results. This has been a 2 month project involving 50+ dyno runs and several tune files. ECU mods are: RPM limit raised to 11,400, top speed limiter removed, timing retard in lower gears removed, ECU unleashed and has a new map. Here is the dyno results with before & after. Currently waiting on pricing, I am setup to be a dealer and will be able to offer Bikeland members a special price. Email me if your interested, senodil@aol.com. PLEASE do not PM me...
fullzx12r
French Guy
posted April 11, 2012 04:24 AM
great !
i think i have the primary map of this project on my 14 ...
zx-12r 01'
zzr 1400 06'
hayabusa 08'
zzr 1400 12'
Seno
BANNED FOR LIFE!
posted April 11, 2012 04:35 AM
The map & "project" was finished up last night about 9PM EST 4/10/12. You might have the "test map", currently there is only 1 bike with this flash & map on it.... Only thing I have requested from the programmers is to have the Traction Control remain in the last mode used when you restart the bike. That would be a very nice feature IMHO...
posted April 11, 2012 06:00 AM
Does this flash have any fuel tunning ? PC still needed ?
Seno
BANNED FOR LIFE!
posted April 11, 2012 06:23 AM
Yes, the flash does have fuel tune. PCV will only be necessary for people wanting to fine tune.
posted April 11, 2012 06:26 AM
What does the a/f look like?
biggmoinc
posted April 11, 2012 08:39 AM        Edited By: biggmoinc on 11 Apr 2012 16:40
That's impressive!!!! I need someone to buy this 12 asap!
biggmo@aol.com
fullzx12r
French Guy
posted April 11, 2012 11:10 AM
at 6000 kms (i have 2200 kms at this moment) i'll see what NUMBERS the dynojet in SAE will give me ...
ps: if you can ask, to ECUnleashed what they give to PIASINI at the end of FEBRUARY ... thanks in Advance, because i have "test map" in fact ...
zx-12r 01'
zzr 1400 06'
hayabusa 08'
zzr 1400 12'
CajunBoyz
posted April 11, 2012 11:51 AM
Yes this would be very nice to be able to leave power in F & TC off...
Seno
BANNED FOR LIFE!
posted April 11, 2012 11:59 AM
Here is the AFR as requested
zx9rmal
posted April 11, 2012 12:05 PM
Thanks for sharing that. Very impressive. What exhaust are you using?
Mal Glanz
Ft. Lauderdale, FL
'12 ZX-14R
Seno
BANNED FOR LIFE!
posted April 11, 2012 12:10 PM        Edited By: Seno on 11 Apr 2012 20:19
Brocks CT, I called Brock's support and spoke to EJ and he said "what pipe am I using?" I told him the CT and then he replied that the pipes are so close that they all use the same map (for pump gas). If you are putting a Brock's pipe on your 2012 14R, you will not need a PCV unless you are interested in tuning every possible HP out of your bike,...
zx9rmal
posted April 11, 2012 12:15 PM
Brocks CT, which is the same mapping for all of pipes made for the 2012 14R available from Brock's.
Thanks.
Mal Glanz
Ft. Lauderdale, FL
'12 ZX-14R
WRECKSHOP
posted April 11, 2012 12:43 PM
Is there any ignition timing changes with the ECUnleased reflash?
biggmoinc
posted April 11, 2012 12:46 PM        Edited By: biggmoinc on 11 Apr 2012 20:47
He said timing retard in lower gears removed
biggmo@aol.com
posted April 11, 2012 04:22 PM        Edited By: smokinZX14 on 12 Apr 2012 00:22
Seno can you ask them a few questions for me .. Timming retard in lower gears ? How much retard and in what gears ? Thanks ....
Seno
BANNED FOR LIFE!
posted April 12, 2012 05:13 AM
*Update*
I have had a few PM's & Emails asking more specifics. Here is a quote from the guy behind the scenes..
"This new tune file is slated to be released on May 1st. There were many changes made, not only to the STPs - which were manipulated to increase intake velocity; this resulted in an increase in hp and torque in the middle, but not on top. Ignition maps were changed, as you said - everything was de-restricted: the separate gear limiters and the top speed limiter are now gone. "On/off" deceleration maps were changed to make the bike smoother through turns, and the fueling was definately changed. Ignition timing alone netted 2 more hp, while the fueling got us the other 6. Torque came up significantly across the board with some good gains in the middle. Another change has to do with modes - with this tune file the ZX14 will remain in whatever mode the bike was in when the ignition is turned off. When you turn the ignition back on, you won't have to "reset" your traction control - the bike will be in the same mode it was in when turned off. I know one guy who lost a race because stock, it has to be reset every time you restart the bike. Several people were involved in this particular tune file, many hours and dyno tuning/testing went into it. POWERHOUSE is responsible for all the fuel tuning that resulted, and all the dyno testing and data logging that got us to this point. There were other changes made internally to the ecu that I have not mentioned . . . all of it will be published when the file is officially introduced May 1st. Stay tuned! "
Hope this answers your questions.
WRECKSHOP
posted April 12, 2012 05:40 AM
Wow. I wonder how this compares to a Guhl's Reflashed Ecu? Can we hear a 2012 ZX14R reflash ECU shootout brewing. Did Don Guhl ever post a Dyno of his reflashed ECU yet?
posted April 12, 2012 05:54 AM
Brock did ..
Viper
posted April 12, 2012 07:11 AM
How much is this flash supposed to cost?
2012 ZX14R SE
cls
posted April 12, 2012 09:29 AM
Great info. Thanks. Keep us posted to details, changes/updates, price, etc.
Thanks, again.
Lucky14
posted April 12, 2012 09:35 AM
*Update*
I LIKE that part ................
cls
posted April 12, 2012 09:55 AM
Here is the AFR, as requested.
A silly question perhaps, but why so (relatively) rich around 4200-5400? That would seem to hurt response and fuel efficiency for us commuters. Any way to tune that out in the flash or is it too minor and/or difficult to worry about? Also, I asked elsewhere, will this thing work in tandem w/a PC-V and a Brock's street map?
Seno
BANNED FOR LIFE!
posted April 12, 2012 12:26 PM
Its rich at that point because of WOT being applied... I asked and was given a technical explanation but frankly it's been a long ass day and I just don't remember. Pulled up to my house and the police were checking the perimeter & had received an "ambush alarm". Funny thing is I am the only one that lives here.LOL, go figure, time to call the alarm guy and say WTF is going on?
cls
posted April 12, 2012 12:40 PM
Par for the course on the alarm. Glad all was well. I wonder if it runs leaner at partial throttle setting (i.e.: More realistice street riding/commuting scenarios.)? I want to get this thing right and then just enjoy it. I hate all this tinkering. I just want to ride.
Thanks. I'll follow along w/the thread.
0.34131503105164 seconds processing time
