BIKELAND > FORUMS > ZX-14.com > Thread: PCV ZX-14R installation pics NEW TOPIC NEW POLL POST REPLY
VINCE12
Designated Drinker.
posted April 06, 2012 05:34 PM
Very easy install so I took pics that some may find helpful.
I removed the tank cover, ram air covers, pitch forks and the left fairing. Right fairing didn't need to come off.
Removed coolant bottle and harness bracket.
Use flat head to push tab and pull wires to unplug. It unplugged very easily.
Crank sensor plug is taped to the TB harness. No need to un-tape it. I wear a Large riding glove and was able to easily reach the plug with left hand and use flat head to push tab and unplug.
Tap into gear sensor, Plug everything in and tuck away. Connect ground and zip tie wires and pretty much done.
2012 Metallic Spark Black ZX14R
Wheelie
Old Man
posted April 06, 2012 05:39 PM        Edited By: Wheelie on 7 Apr 2012 01:40
Lucky14 and I were just talking about the install, mine will be here tomorrow, when I get home from the deer lease I will install it, Thanks for the detailed photos.
wee
posted April 06, 2012 06:55 PM
Good Job and thanks for the write up and pictures ...
Lacker 14
posted April 06, 2012 08:40 PM
Mounted under the seat? Hopefully that can be done
blue07
posted April 06, 2012 09:26 PM
Yeppers...thanks for those pics.Got one coming as well...along with a single Brock's CT Titanium system.Any 'tricks'to installing those headers anyone?Thanks
VINCE12
Designated Drinker.
posted April 07, 2012 10:05 AM
Put mine under left ram air cover. Under the seat could probably be done with a bit more work.
Wheelie
Old Man
posted April 07, 2012 06:44 PM
just installed my pcv, this how to makes it so easy, Thanks
wee
Viper
posted April 08, 2012 09:11 AM
Also u can leave the cable hooked up to the PCV and stuff it under the ram air cover too. That way u can use it without removing ram air covers.
2012 ZX14R SE
0.24063587188721 seconds processing time
