BIKELAND > FORUMS > ZX-14.com > Thread: case mod. to get oil on crank NEW TOPIC NEW POLL POST REPLY
CJ
posted March 16, 2012 07:45 AM
Does anyone have any pics of the oil modification that they r making to the casing? Also as anyone removed just the bottom counter balancer for better oiling if not can it be done and not have the crank off balance with the top still in? Going to install muzzy oil pump cover while I have engine apart. Any good advise and ideas on oil system modifying greatly appreciated.
07 plasma blue zx14
Ain't no fun when the rabbits got the gun
06redzx14
posted March 16, 2012 08:32 AM
http://www.bikeland.org/board/viewthread.php?TID=60997&FID=13
Compton
posted March 16, 2012 09:18 AM
slow down oil going to trans, put in balancer deletes and block off oil going to the galleries. some block off the squiters some leave them
b.w.
06redzx14
posted March 16, 2012 09:43 AM
What type of epoxy should be used to slow the oil to the trans?
Oz Booster
posted March 16, 2012 12:22 PM
I used a 260c hi temp knead type epoxy from a stick , was going to grab my JBweld but must have put it some place safe . and this other stuff was on my shelf and a higher temp rating .
But i do like the suggestion by Ken (Rich Craft 1) when i asked a similar question here
http://www.bikeland.org/board/viewthread.php?FID=27&TID=65992&set_time=
0.26088500022888 seconds processing time
