BIKELAND > FORUMS > ZX-14.com > Thread: Can these cams be reused? NEW TOPIC NEW POLL POST REPLY
06redzx14
posted March 14, 2012 05:55 PM
Purchased a motor from a bike that caught fire.
Now for the cams
Did some research and the cams are web 395/378 I think
What do you guys think can they be reused?
AcadianaZX
Advertiser
posted March 14, 2012 06:11 PM
That is a good deal on the sausage gravy. lol. Send the pics to web and they will probably say run them.
Good luck.
06redzx14
posted March 14, 2012 06:36 PM
Just a FYI i haven't even tried cleaning them yet
kawa74
posted March 14, 2012 07:44 PM
Look ok, but , Get a caliper and measure from bottom to top of lobe, turn cam 90* and then measure base circle of lobe, ( round part at the centerline of Base} subtract from height = lift.
Measure all lobes, bearing surfaces.
"I have never met a man so Ignorant that I coun't Learn from him"..."Galileo"
Grinner
posted March 14, 2012 11:24 PM
Also you need some very fine emery cloth and clean the areas up to see close up the actual damage, I know you havent cleaned them but you need to to confirm any damage or wear......then post some close ups of the lobes..
Oz Booster
posted March 15, 2012 12:38 AM
Heat was mostly above them, they have virtually no color change and would not affect the temper, clean up the bearing surfaces and lobes with some fine wet paper , just to remove the rust and baked on oil and check for baked oil inside the cam , also check straightness with a dial gauge , if one side was heated and the other not it may bend the cam slightly , otherwise if that all checks out i would use them without a second thought
The aluminium cam caps would be damaged well before the cams
06redzx14
posted March 16, 2012 09:02 AM
Lobes cleaned off pretty easy with 2000 grit emerial cloth
0.2428879737854 seconds processing time
