BIKELAND > FORUMS > ZX-14.com > Thread: electric or air shifter? NEW TOPIC NEW POLL POST REPLY
Lsantana954
posted March 12, 2012 08:38 PM
Looking to get an auto shifter and would like to get everyone who has personal experience with the 2. Pros and cons, i am aware in the price difference. I do like that the Pingel electric shifter can down shift as well as up.
'12 Gully Blue ZX14
-PCV/Guhl ECU/Blue CT Meg/<0 Alyson Oil/+8 Evil Arm/+1 Rear Sprocket
'07 Acura TL-S
'87 Buick Grand National
Seno
BANNED FOR LIFE!
posted March 13, 2012 04:18 AM
It's really a mixed bad...What will you be doing with the bike? If your riding on the street electric is a lot more "user friendly", no need for on board compressor or having to deal with making sure you have enough air for a day or riding around. If your drag racing it, air is the way to go. I know the Pingel can downshift, but will you really take advantage of it? Just my 2 cents. I had a holeshot electric shifter and it was descent, but the cable/linkage had to be adjusted occasionally.
Lsantana954
posted March 13, 2012 09:36 AM
It will be used for the strip with occasional street use
'12 Gully Blue ZX14
'07 Acura TL-S
glarior
posted March 13, 2012 09:49 AM
I run air shifter but using my nitrous. Takes almost nothing to use. Friend uses a setup he made for air shifter and works great. Both are used for drag, land speed and street.
I have not used an electric setup so I can't compare.
Texas Mile - 201mph
LTA - 221.18mph track record... for now
Mojave Mile - 213.2mph
Texas Mile Beeville - 210.5
http://www.youtube.com/user/horsepowerMafia
mathews
posted March 13, 2012 11:40 AM
I have had my Pingle on two different bikes over a period of 7 years.Works great.It is bulky and their electronics suck.I ended up with an MPS auto-shift box and it works great
BrucerZX14
posted March 13, 2012 12:47 PM        Edited By: BrucerZX14 on 13 Mar 2012 20:47
There's also a Dale Walker Power Shifter. It uses a large solenoid with cable attached to the shifter. Works good. I used one on an '03 Yamaha R1. Just gotta remember to turn it on. I went with air on the ZX14 because the solenoid is big and couldn't find a spot to install it.
pazx14rider
posted March 13, 2012 01:06 PM
I had the pingle electric on my 07 but didnt have the auto shift with it. I looked into it, but you needed the pingle auto shift box plus a dyna shift minder put all that together thats a heafty price to pay for the auto shift. I now have a MPS autoshift on my 2012. I have a Macintosh arm with the air tank, got a slime compressor from schnitz and the MPS auto shift box and both those units fit inside the battery compartment...I like my air shifter better than the Pingle fyi
bigwil
06 zx 14 turbo stage 3
posted March 13, 2012 05:11 PM
high pressure shifter get 800 shifts from a 1lb bottle and if your running a powecomander you can just put a muti hub it has 2 rpm leads you can set any rpm to shift, set nos, a shift light. no pills no shift box no air compresser add all the
one santana to another
bigwil// going fast aint easy so turbo it
0.2427179813385 seconds processing time
