BIKELAND > FORUMS > ZX-14.com > Thread: 09 zx14 giving 62 code NEW TOPIC NEW POLL POST REPLY
Viper
posted March 12, 2012 06:03 PM
Anyone ever have a 62 fi code on the 08 up 14s? If so what was the cause
2012 ZX14R SE
Wheelie
Old Man
posted March 12, 2012 06:20 PM
code 62-Subthrottle valve actuator malfunction? googled, not for sure...
wee
shawnski
posted March 12, 2012 07:34 PM
have you done anything different to the bike?? removing anything ??
Viper
posted March 12, 2012 07:39 PM
He pulled the motor changed cams degreed and put motor back throttle bodies stayed in the bike.
2012 ZX14R SE
shawnski
posted March 13, 2012 03:51 AM
He pulled the motor changed cams degreed and put motor back throttle bodies stayed in the bike. [/quote
Does the bike runs at all??
I thought I saw here somewhere that it can be reset... Do a little search...
1badzx12r
posted March 13, 2012 04:06 AM        Edited By: 1badzx12r on 13 Mar 2012 12:06
i had this happen before .. it was caused due to the sub-plates sticking and putting a drag on the actuator .. the sub-plates need to move freely
Viper
posted March 13, 2012 06:18 AM
yes the bike runs but when the code is given it richens the fuel up. the flies have long been removed, he's tried 3 different sets of throttle bodies. he's changed the wiring harness and even the ecu.
2012 ZX14R SE
1badzx12r
posted March 13, 2012 06:59 AM        Edited By: 1badzx12r on 13 Mar 2012 15:01
then check the ground junction blocks..the zx14 has like 3 sets of ground junctions and this would be where i would go next.. the 1 on the left( Clutch lever side) over by the ram air inlet is subject to failure.. condensation will turn the copper green and short the switch ... i've had this happen on several 14's tiggering the 42 code for cam sensor.. maybe its doing the same for your code
Viper
posted March 13, 2012 07:34 AM
I told him and he is gonna check that ground. He said this was puzzling why this one bike did that out of the other 3 14s that he has. he did the same thing to all of them
2012 ZX14R SE
Viper
posted March 15, 2012 10:29 AM
The grounds were good. His light comes on when he is in traffic or just cruising. If he is moving pretty good it doesn't come on.
2012 ZX14R SE
0.28749084472656 seconds processing time
