BIKELAND > FORUMS > ZX-14.com > Thread: Ricky Gadson is getting faster !!! NEW TOPIC NEW POLL POST REPLY
posted March 11, 2012 03:26 PM
New tire, Brocks clutch mod and a new drag shock ...
dakota9498
posted March 11, 2012 03:28 PM
He is getting it done for sure, especially at that wheelbase.
2008 ZX14
dakota9498
posted March 11, 2012 03:31 PM
It looks like that Busa's 8.42 will be in danger way before a set of BST's and all of the other tricks are even employed.
2008 ZX14
posted March 11, 2012 03:32 PM
posted March 11, 2012 03:33 PM        Edited By: Shane661 on 11 Mar 2012 23:33
Flying at 64", and what, 170+ suited???
posted March 11, 2012 03:34 PM
Flying at 64" and what, 170+ suited???
I read on one of his posts he said with gear 168 ... Close to 170 for sure ..
posted March 11, 2012 03:36 PM
He also said this was on pump gas this time around...
posted March 11, 2012 03:39 PM        Edited By: Shane661 on 11 Mar 2012 23:40
Nice!!!! That means an "average" guy like myself has a chance of running in the 8's on pump, even at 215 lbs suited...at 64".
Kaw Man
posted March 11, 2012 03:40 PM
That hauling mail
  Ignore this member    Click here to send Kaw Man an AIM message.
kaw-rick
posted March 11, 2012 03:43 PM
what tire?
Guess i need to order a drag shock real soon !! I just have a hard time paying out 2k for a shock ... I'm going to need some kind of edge to get my ETs lower because we just don't have the air here in FL that they have up north ..
Looks like pump gas works better than MR12 ... MR12 might work with a tune but not just pouring it in with no tune ..
posted March 11, 2012 03:45 PM
what tire?
Rickys post on Facebook .. "At the track today testing the new Brock's clutch mod,Ohlins drag shock, and the new for drag racing Conti-Attack 2 rear tire by Continental."
Hayabusa14
posted March 11, 2012 03:46 PM
Where did you get your drag shock from Ricky?
2012 SE-ZX14R [CT Meg-PC5 with street map-Evil swingarm 64" wheelbase-JRI shock], 2009 GSXR 1000, 2008 B-King, 2007 SE-ZX14 "Brocked out" - 1999 Hayabusa "stage 1" Turbo
posted March 11, 2012 03:47 PM
Ohlins drag shock..
Hayabusa14
posted March 11, 2012 03:48 PM
Thanks Lee
Bently
2012 14r In Blue and no Mods!
posted March 11, 2012 04:24 PM
I've said it before that Ohlins shock flat works! My bike hooks to a 1.44 60 foot on an outlaw track we run at that does no track prep.
posted March 11, 2012 04:26 PM
I wonder how brocks EZ drag shock stacks up to the ohlins drag shock .. Other than the color of the shock they look the same ..
posted March 11, 2012 04:47 PM        Edited By: smokinZX14 on 12 Mar 2012 00:54
That Ohlins drag shock really seemed helped Ricky ... With the stock shock he was running 1.40s and with the drag shock he going low 1.30s .. That tells me it doing it's job i think....There could be other mods coming into play that i don't know about ..
The problems i'm having with my stock shock on my new bike i didn't have with my old bike .. I'm sure it's do to the extra power of the new bike .. My problem is when i hit a 1.30 to 1.31 60 footer the bike leaves the line with the tire on the ground but as i move down the track the bike starts coming up , i have to trim the throttle to keep the tire from going too high ... Now when i back off a bit and run a 1.34 or 1.35 it will not do that and i can keep the throttle pinned in first gear .. I can run 8.52 with the 1.34 to 1.35 60 foot time ... When it hit 1.30 to 1.31 and have to trim the throttle i run 8.54 or 8.55 .. I'm sure if i get a 1.30 to 1.31 60 and keep it pinned it will go high 8.40s .. I think Ricky was having the same problem as me till he replaced the shock .. If i could be 100% sure this is my problem i'd order the shock right now .. I'd sure like to test one before i drop a grand on it ....
posted March 11, 2012 04:51 PM        Edited By: smokinZX14 on 12 Mar 2012 00:52
posted March 11, 2012 05:04 PM        Edited By: smokinZX14 on 12 Mar 2012 01:09
In this pass you can see the bike coming up , i had to trim the throttle just a bit ( not pin it ) to keep it from coming up too much .Had i pinned sooner it would have really screwed up the pass ...I knew the second i did that i would not have a high 8.40 pass .. If a good drag shock would fix that i'd be a happer camper ..
Wheelie
Old Man
posted March 11, 2012 05:25 PM        Edited By: Wheelie on 12 Mar 2012 01:26
Smokin, I hope that shock helps, but you get to a point when leaving as hard as possible the wheel will lift, nothing will stop that except a longer wheelbase, shock may help some but there is a limit on 60ft times even with the Ohlins.
wee
kawasakijockey
posted March 11, 2012 05:58 PM
I dont see how a dragshock is a waste of anyone's money. They are just so responsive to tuning. Mine still will wheelie with the dragshock but I really havent finished messing with it. Stiffening up the spring and compression is supposed to stop so much transfer onto the back tire which makes the front go light and into a wheelie. That is the next step for me to try out. Put too much stiffness in it and it will spin like crazy.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted March 11, 2012 06:08 PM
wee
Well i would hope it would help .. I was able to go 1.31 at 62 inch wheel base and not wheely on my old bike , so one would think at just over 65 inches i could go 1.31 without a wheely on my new bike .. I can't go any longer with my arm , so i need to come up with something that works .. Looking at the good side it's nice to have a bike with so much power to work with ..
Wheelie
Old Man
posted March 11, 2012 06:15 PM
wee
Smokin, listen to the clutch action, it's not smooth, being more linear with it will get you a better time, you will be able to pin it and stay in it.
Pretty easy for me to tell you how to race huh LOL, really I think a smoother clutch release will get that .49 or better.
wee
posted March 11, 2012 06:24 PM
wee
wee
Wee i don't rule anything out ...
0.23938989639282 seconds processing time
