BIKELAND > FORUMS > ZX-14.com > Thread: Rattle behind the windscreen. NEW TOPIC NEW POLL POST REPLY
lucassm
lucassm
posted March 10, 2012 06:12 PM
I know this is prolly old news to everybody on here but it was new to me. So today after alot of messing around I killed the rattle. I removed the windscreen like all the threads said and sure enough the tip over switch was loose. So after scratching my head and cussing alot I figured I could take the factory sleeves out of the rubber add a rubber washer on the nut side of each bolt and tighten it down tight this time. Then I decided to take the whole mount off and put a rubber washer between the bracket and where it mounts too. Took it for a ride and bingo no buzz up front. I know its a normal noise but things like that drive me nuts. So Ihad to figure it out. If this is old news im sorry but if it helps one dude fix the buzz then Im happy to help.
posted March 11, 2012 08:00 AM
i wrapped mine in foam and tape six years ago to kill the noise
0.32600402832031 seconds processing time
